Dell 3000cn Laser Printer Logo
Posted on Apr 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What to do when toner is low - Dell 3000cn Laser Printer
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Apr 16, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557387
Points
31058
Remove the toner cartridge.
Gently "roll" it from side-to-side, to evenly distribute the toner. Do not "shake" it.
Eventually, you'll either need to buy a new toner-cartridge (either from Dell or via eBay) or find a store that refills ink-jet and ink-toner cartridges.
22helpful
5answers
Konica minolta pagepro 1500w toner low error
recharge toner powder. 'BROTHER' toner powder is suitable for it.rate 100 Rs. only.
Lexmark e260dn toner light blinking orange
Solution: If you replace the toner cartridge and the 'Toner Low' message remains, the printer may need to be reset.
To do so, power off the printer. Let it sit 20 to 40 seconds, then power it back on. If the 'Toner Low' message does not appear on power-up, try printing again.
If the 'Toner Low' message returns on power-up or when printing, confirm the following:
  • The toner cartridge you just installed is a brand new toner cartridge and not a used one.
  • The toner cartridge is an original Lexmark brand toner cartridge. Cartridges manufactured by a third party may not be compatible with the printer.
    If a third-party cartridge is causing this issue, contact the point of purchase for additional support or replacement of the toner cartridge.
  • The toner cartridge has not been refilled or refurbished by a third party. If it has, contact the place where it was refilled to have it replaced.
Still Need Help? Should you confirm all the above and the 'Toner Low' message remains, have the following available when calling Lexmark Technical Support;
  • Printer model(s)
  • Printer serial number
  • Toner/imaging unit/waste toner bottle part number and serial number
1helpful
Toner low and error is flashing
Your PC has detect low toner in your printer that led it show error flashing. Normally It can cause by 2 things : 1. You have a low toner ( need to replace toner) 2. You have a clogged up toner ( need to clean /service the printer)
1helpful
2answers
Low Toner Message
Canon sucks. That is the answer. They want to make money off of you and want you to buy toner all the time even if you don't need it. It is called planned obsolescence and it is disgusting. They also make life difficult for aftermarket cartridges too. They don't make a lot of money on the printer itself so they make up for it by trapping you in a never ending cycle of buying toner!
J2, toner low, but powder in toner cartg. Remove
All this means is that your toner is getting low and advising you before it is out completly the it needs replacing.
Toner low we installed new toner. then message
remove plastic cover from toner yellow or any color and install toner properly.
2helpful
Received "Low Toner" message. Replaced toner with new Brother cartridge still have "low Toner" meaasge and [printer will not print.
Please check if you removed the Plastic Tapes which is placed in the side lock of the new Toner Cartridge.
2answers
Toner low indication
Take out toner and shake up down . And put it again. may it will help you . Else let me know.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
