Question about Dual DWM-3900 System
Shuts down after a few minutes
I think the unit is overheating.
Fan is not coming on at all !
Took fan loose and hooked it to a battery and it checked out good !
So my question is why isn't the fan coming on !
  • 1 more comment
  • PrettyBlak Oct 25, 2008
    I have the same problem. it plays for about 2 minutes and shuts off.
  • dantoa49 Oct 26, 2008
    checked fans not turning-no 12vdc present at testpoints
  • jerrip Feb 22, 2009
    I also have the same problem. Any ideas?
    New Friend:
  • 99 Answers
Have u solved the problem or still needs help, post me
Rifaa
Posted on Nov 08, 2008
SOURCE:
Notebook 3521 is shutting down after some minutes for unknown reasons. Any suggestion about the problema?
Common problems are faulty battery, or overheating due to faulty fan. If the machine shuts down when on mains power, listen carefully for the fan. If the fan is silent or slow , you could try using a vacuum cleaner to clear any fluff out of the fan unit or get hold of a laptop cooler tray. If the unit doesn't shut down on mains power, you should get the battery checked.
Mar 02, 2015 | Dell Inspiron 15 Notebook Inspiron 3521
My computer is randomly shutting down. Sometimes it will work and other times it will not. I think the processor is overheating and causing it to unexpectedly shut down. the screen goes black, the power...
Few reason for the shut down
Could be heat, electrical,
1. try cleaning all vents with compress air in order to remore dust and fuzz that can be cloging the vents.
Once this done, verify that fans works proprelly,(check air flow coming out of vents) if they dont they will need to be replace or cleaned out.
2. Check power supply unit, and battery.
Sometime power supply unit is defective, getting too hot and power output is not stable and shuts down the laptop. ( change power supply unit) check if battery hold charge. if not change battery
3. Check connections for looseness and contact
If all seems normal,and none of the mentionned point seem to be defective, the cause is deeper and would need to be looked at by a technician.
Sep 29, 2010 | Acer Aspire 7520-5185 Laptop
Computer is a Lenovo TC M52 P4 / 3.2 - I have added a sound card, a PCI express Geforce graphics card and a NIC card. The problem seems to be overheating as it only shuts down like this during the summer...
The case fan should start running as soon as you turn on the computer. I would replace the fan with a higher capacity (CFM). If you have a case that can take 2 case fans, I would install the send fan. Also with the case off, check that the CPU cooler fan is functioning. With the quick shut off, I would suspect that the CPU cooler fan is not functioning. I could be impeded by dust. Vacuum and blow out any dust on the motherboard, fans and battery fan while you have the case off.
This should aleviate the shutoff problem due to overheating.
Let me know if this solves the problem.
Please rate this solutution. Thanks.
Jun 23, 2010 | Lenovo ThinkCentre M52 8212 - Pentium D...
A/C starts up/Cools/Fan Slows, Unit Shuts down in 4 minutes
Ensure proper voltage to the unit. Check for overheated/damaged wires and/or connections in the control panel as well as at the fan motor and compressor.
Apr 03, 2010 | Dometic Rooftop RV Air Conditioner
Samsun HT-WX70 overheating and shutting down
The receiver in the Samsung ht-wx70 system that I have runs fine until all of a sudden I hear a loud bang and it shuts off. If I touch the unit, it is burning hot. I took the fan out and it works when I attached it to a 9v battery. Is it the fan or another problem that I should be looking at.
Oct 04, 2009 | Samsung HT-WX70 Theater System
I took my gateway gt5620 in because it would shut down by itself. It would restart. They took the graphics card out and it worked for a while. Now it is doing the shut down again. I took the side panel off...
Sounds like an overheating problem. May want to remove the processor and check the heat sink material. While you have it out you can clean the fan and the heat sink. Make sure your air flow isnt blocked in any way and neaten up the cables if necessary. You could also consider adding another fan.
Oct 01, 2009 | Gateway GM5620 PC Desktop
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
The unit runs for a few minutes and completely shuts down
Without the model or make sound like a bad thermostat..check amps the the compressor and voltage... if the compressor is locking up or the thermostat cutting voltage to it..
Hope this helps
Apr 05, 2008 | Refrigerators
Overheating?
Hey,
I think it's the cooling... Because when i let it cool down after it shuts down for like a few minutes I can boot it back up. But if i try to boot it up right after it shuts down it won't let me. I think it has a built in temperature monitor to make sure it doesn't overheat. I'm going to install some computer fans on the vents of the projector to get some more airflow. Hopefully that will do the trick.
Nov 03, 2007 | CTX Optoma EzPro 680 Multimedia Projector
Quick Flipoff
The air intake vents in the rear were clogged with dust. They needed to be brushed and vaccumed.
Oct 31, 2007 | Lasko 5132 Ceramic Compact Heater
Dual DWM-3900 System Logo
254 people viewed this question
Top Dual Audio Players & Recorders Experts
Michial Gueffroy
Unspun01
Level 1 Expert
Lawrence Oravetz
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
