Question about HP LaserJet 1020 Printer
Printer not acknowledging sent document
We have shut down the computer, checked printer settings, turned the printer on and off and unplugged and replugged.
    Genius:
  • 3,587 Answers
Ok....sent document as in as a fax?
Posted on Mar 21, 2008
How can I stop it from printing over and over again
you have clear the print buffer in the computer.
by clearing out the buffer, unplug the computer after ward and than also unplug the printer too, that should clean the memory in the printer itself.
GO TO START CLICK ON START GO TO DEVICES AND PRINTERS, OPEN THE FOLDER CLICK ON THE PRINT YOU ARE HAVING ISSUES WITH DOUBLE CLICK IT WILL SENT YOU TO CHECK LIST OF OPTIONS THE FIRST ONE.
1. SEE WHATS PRINTING, CLICK TO OPEN
2. HIGH LIGHT PRINTER THAN SCROLL DOWN TO CANCEL ALL DOCUMENTS.
YOU SHOULD BE DONE
BUT YOU STILL HAVE TO CLEAR THE MEMORY THAT STORE INFORMATION IN MEMORY INSIDE THE PRINTER
BY TURNING OFF MAY NOT BE ENOUGH YOU MITE HAVE STILL UNPLUG IT TO CLEAR ANY OR ALL MEMORY FILE
THANK YOU ROD
Mar 03, 2015 | HP Office Equipment & Supplies
Printer does not print computer documents
The queue is so choked with documents the printer gets confused and loses its sense of priority. Shut down the printer and disconnect power to clear its memory. Wait a few minutes and reconnect power. Start sending one document at a time to the printer and you should get results.
Mar 08, 2014 | Samsung Office Equipment & Supplies
HP Officejet 5610v: Sent document to print. Somehow the settings were set to print offline, so nothing came out. I "unchecked" the "print offline" option. I tried to...
This Utility program resolve all the printing issue for HP Printers ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
This Utility program will fix all these issues.
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Feb 21, 2011 | HP Officejet 5610v All-In-One InkJet...
We had a power outage last night and now every light on the printer is flashing. I have shut down everything, reconnected, uninstalled and reinstalled.
turn on/off, unplug, plug in2_bing.gif, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should reset printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Brother HL-5240 Laser Printer
HP C6100 Printer caught in on off cycle
i had this happen once a long time ago, try these options below...
turn printer on/off, unplug,wait a minute plug in2_bing.gif, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. hp has an AWESOME web site for trouble shooting
Apr 29, 2010 | HP Photosmart C6100 All-In-One Printer
An incorrect document was sent to the printer. The printer continues to try and print the documents and will not stop. Is there a way to "erase" the memory of documents in the printer "queue"?
Hello.
Of course there are. Just press on "Printers And Faxes" in "Control Panel" and double click the printer you use.
Locate and press "Printer" on menu toolbar in this new window and then "Cancel All Documents".
If this procedure is taking too long, shut down your computer and unplug your printer, then restart computer, replug printer. Try to "Cancel All Documents" again
Good Luck
Jan 25, 2010 | Lexmark Forms Printer 2381 plus Matrix
Second "alignment" page prints after every document
What you need to do is clear the printer's internat cache. Do do this, Unplug all cables from back of the printer. Leave it unplugged for at least 5 minutes. While it's unplugged, shut down & re-start your computer. When it finishes booting up, re-connect all cables to your printer & to the pc and turn on the printer. This should solve the problem.
Jul 25, 2009 | HP DeskJet 5550 InkJet Printer
HP3210 powers off
In order for HP to get an ENERGY Star rating the printer must go to sleep.
No way to override.
Jul 12, 2009 | HP Photosmart 3210 Printer
Aspire 9301 awsmi
Shut down the computer and turn off the printer.
Disconnect the printer cable from either the printer or computer.
Unplug the printer's power cord from its power source.
Restart the computer and log onto a desktop.
Shut down the computer again.
Reconnect the computer to the printer.
Plug the printer power cord back in and turn it on.
Once the printer cycles through its power on self check, power the computer back up and log on to a desktop.
The icon should be gone now if you have followed these steps completely and in this order.
Please don't forget to rate and thanks for using FixYa.
Regards,
Worldvet
Sep 07, 2008 | Acer Aspire 5050-3242 Notebook
HP LaserJet 1020 Printer Logo
44 people viewed this question
Seeker5211
Seeker5211
