Question about HP LaserJet 4 plus Printer
Hello 50 service appears on the screen >>>
  • 3 Answers
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Posted on Apr 03, 2008
Dear
. I have problem with
HP laserjet 1522nf . I get the message " 50.2 Fuser error, Turn off and Then on"
I do it but print is not good. 1/4 to 3/4 is bad print. Print is not strong and can be errased by rubbing with finger. Thanks
Posted on Oct 11, 2012
    Genius:
  • 3,587 Answers
It's time for a service call..that's usually the engine making it's issues known..had this a while?
Posted on Mar 20, 2008
Every 3-4 minutes screen goes black and Smart TV logo appears; 2-3 seconds returns to program I'm watching (live TV0.
Hello
Open your set, disconnect and reconnect all the connections
Probably a connectivity problem
Good luck
Apr 06, 2016 | Samsung UN50F5500 50-Inch 1080p Smart LED...
My 50" plasma fell and
hello linda...
Plasma screen can be replaced with the new one, but its expensive like you buy new one.
Call samsung service center for informations.
Jun 28, 2011 | Samsung 50 in. Plasma TV
Hello! on the screen it appears "Fill beans
hi you need the grinder stripped and serviced .. or might need new grinder... bsc appliances 07779933829 we have a postal service to repair too.
Feb 27, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
VS-50111 and horizontal lines appear and shuts off
hello i have the service manual which i'll send for free along as you leave me a fair rating thanks
regards
shaun
May 31, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Replaced lamp and a yellow halo still appears on the screen
This means that the light engine is dirty or burned. The hot glass directly in front of the lamp may be burned.You will need to find a shop that is capable of repairing DLP projectors.
Jan 01, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
50" Samsung Plasma with black screen
I had the same problem and had the TV serviced and found that the y board was blown $350 total. The repair guy explained that the board has a hot transister underneath that slowly leaked onto the board, but says that they can not get Samsung to admit to the problem. Works fine now but only have a 90 day warrenty on the parts.
Dec 01, 2008 | Samsung HP-S5053 Television
TH50PX60U screen issue
If the screen is cracked (glass is broken ) you will have to replace the panel at about 1200 to 1500
Nov 24, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Plasma screen
Hello Osito,
Your power supply is sensing trouble in any of the other PCB. That is why the relay clicks in and then out. Unfortunately, Plasma is a PCB level. Cant touch any in there except maybe some visible blown cap on the power PCB.
Try the service support from your dealer. sorry, can't be much of a help.
Dec 21, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Blue and red shadows on screen
This sounds like one of the convergence IC's has cracked loose or burned out, and should be replaced and realigned by someone with experience.
Jun 26, 2007 | Hitachi 50UX57B 50" Rear Projection...
HP LaserJet 4 plus Printer Logo
1,234 people viewed this question
Ben Johnson
