Question about HP 920 Plain Paper Fax
Canceling a print job?
A big fax came in 32 pages. I need to cancel this print job.  HOW?  Help! can't use my fax because of this....... What do I do?
  • brownb Mar 20, 2008
    some please answer HP tech support won't help.  Is there a HP FAX chat help room out there, with suggestions or directions
    brownb
    Genius:
  • 2,120 Answers
Remove paper....unplug power....hold down 3 and 6 and plug in.
Posted on Sep 10, 2008
SOURCE:
How do you clear the fax memory on a OCE FX3000? Says memory is full. Not connected to a pc just use machine for copies and fax
Check your owners manual. your machine may be out of memory. To free up extra memory, you can turn off
fax storage (see Turning off Remote Fax Options on page 64), print fax messages
in memory (see Printing a fax from the memory on page 46) or cancel a delayed
fax or polling job (see Checking and canceling waiting jobs on page 38)
Sep 14, 2016 | Office Equipment & Supplies
HO C4200 DOCUMENT STUCK IN QUE CAN'T DELETE
First You Need to Open the Print Queue, follow the below steps on how to open a Print queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double click on the appropriate printer to open up the Print queue,Check whether you have any pending or the queued jobs, try to cancel the jobs by following the below steps.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
• To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
• To cancel all print jobs, click Cancel All Documents on the Printer menu.
If you are using an HP printer and a windows vista operating system then you are lucky to automaticlly fix the issue with the HP Print Diagnostic UtilityClick Here For How to cancel printing or to delete a print job that is stuck in the print queue in Windows XP.
Alternatively You can check the below steps.
Delete Pending Jobs
How To Restart Spooler restart In Windows Vista
Click the Start button.
Click Control Panel.
Click System and Maintenance.
NOTE: This step is not required when using Classic view in Windows Vista.
Click Administrative Tools.
Double-click Services.
On the User Account Control window, click Continue.
Click Print Spooler.
Click Stop to stop the Print Spooler.
Click Start to restart the Print Spooler. Then click Restart
Click OK
Hope this helps!
Thanks!! - See more at: http://hpanswers.blogspot.com/2008/10/cancel-and-delete-stuck-print-jobs-in.html#sthash.QD3KNI9q.dpuf
Jul 01, 2014 | HP LaserJet 4200 Printer
How to cancel print task
If you are using XP in the bottom right corner you should see a small printer icon. Click on it (you mite need to click on the arrow to expose the printer icon) Then right click on the job and cancel it. Steven
Feb 05, 2010 | Brother HL 1440 Laser Printer
How to cancel a transmission
Pages 110 & 111 in users manual. During a direct transmission, press stop. For memory transmission, press job cancel, then select one of the 5 choices to cancel. 1.Transmit 2.Receive 3.Polling 4.Polling Reserve 5.Job Number Use the number keys to select the choice. Press Enter to cancel the selected job. To confirm deletion press1.
Oct 06, 2009 | Toshiba DP-85F Fax
How can I delete pages from the Brother 210C printer that I do not wish to print^
For Windows XP - click Start, Control Panel, Printers and Faxes
Click on the printer to open up the printqueue. To cancel a print job, right-click on it and click cancel. To cancel all print jobs, click Cancel All Documents on the printer menu.
More information can be found on this website (this should work for any printer): http://hpanswers.blogspot.com/2008/10/cancel-and-delete-stuck-print-jobs-in.html
Nov 10, 2008 | Computers & Internet
Deskjet 3520. I mistakenly clicked on print a 200 page document when I only wanted 7 pages. I cannot stop it from printing. Tried cancel and even unpluging it and each time I reconnect, it continues to...
Click on control panel, then double click printers and faxes, then double click the printer you are using, a panel will appear, and you click on the document name you have entered, then click on document, then cancel and click yes when asked if you want to cancel the print job. It will take it a little while but it will clear the job you have entered.
Aug 22, 2008 | HP Office Equipment & Supplies
Lexmark 5400 incoming fax job wont print
from the Lexmark website:
This issue occurs when the user sends a fax using the flatbed scanner. After the first page is scanned, a message is displayed asking if another page needs to be scanned. The user options are YES or NO.
  • If the user chooses YES or NO and the fax starts to dial, they can safely press CANCEL without inducing the problem.
  • If the user presses the CANCEL button instead of answering the question, all future received faxes will go to memory instead of printing out. NOTE: There is no direct means of recovering a lost fax, but unplugging the machine and reseating the power supply will restore normal operation. An error report will be printed and provide information about the lost fax, which may allow the user to contact the sender and request that the fax be sent again.
Jan 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP 920 Plain Paper Fax Logo
67 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
