Question about Canon PowerShot A520 Digital Camera
Shutter button not working
After droping my camera the shutter button now doesnt work. everything else is ok. turns on, screen works, lens zooms in/out ok, no error codes.
  • 1 more comment
  • Anonymous Jun 04, 2008
    where the lens can move out and in does not open
  • Anonymous Jun 10, 2008
    Lens stuck open.
  • Anonymous Jun 21, 2008
    camera was dropped and now the lens is stuck and a red screen on the display!!
    Scholar:
  • 46 Answers
Dear phill523:
Unfortunately the solution is to call Canon (1-800-828-4040) and send the camera into the Service Center for repair.
Hope this helps a bit.
Sincerely,
HeavyDLB
Posted on Jun 03, 2008
I have a zoom error alert on the screen of my fuji j37 digital camera. When i turn the camera on the lens comes out and retracts straight away.
I had this problem for the first time yesterday, on my fifth use of the camera from new. The user manual says to turn it on and off a few times which I did but to no avail. I found advice on a different forum that said to hold your finger over the shutter as you turn it on, so that the lens doesn't have time to retract again. Sort of use your finger nail to hold the shutter up while the lens extends. Tried this and it worked, switched it off and back on agiain and it seems to be going fine now.
May 16, 2010 | Cameras
Canon PowerShot SD780 IS camera lens error. :(...
I did the same thing and it works only be restarting it now but it works lol. I threw it agianst my bed . SO BEAT THE **** OUT OF YOUR CAMERA..then restart and it should work..*** made **** what can you say
Jul 28, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
Nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
Apr 15, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
System error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Listed Fix #4 might work for you. Place the camera on its back, and hold the shutter button down while powering on the camera.
Dec 21, 2007 | Nikon Coolpix 3200 Digital Camera
Canon error code 99
Your camera performs a quick 'integrity' check before each shot and goes into error 99 mode if the lens in incompatible or has a diaphragm problem. ( it will also display e99 if the shutter or flash unit is not ok but this does not apply here ). This is how you can check whether the diaphragm mechanism is ok : attach lens to your old camera and set camera to AV and set F stop to 16 . open back and release shutter and look through the back to see if your lens is closing to F 16. If it is closing fine then the lens is ok but is not compatible with your D400.
Sep 10, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
23 Error Code.
Listing of Pentax codes E3, E7, E37: These codes often signal a problem with your shutter mechanism. E9, E93-E97: These codes may indicate a problem with your zoom lens. H0-H9: These H codes can also identify a problem with your camera's shutter. U1-U9: These U codes may also indicate a problem with your camera's zoom lens.
Jul 14, 2007 | Pentax IQZoom 60S 35mm Point and Shoot...
Regarding Error #45
Well Heero if you are the tech guy you say you are- and Kodak arn't helping you- this suggests a mainboard failure and the camera is not going to get repaired.
Jun 05, 2007 | Kodak EasyShare LS443 Digital Camera
Canon PowerShot A520 Digital Camera Logo
69 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
