Motherboards
Problem for Motherboards
Generic problem for all Motherboards
Asus P4T-M version 1.05 Not Posting?
By ed12371 on Mar 20, 2008
I'm trying to put this very old system together and for some reason it will not post? The System fires up , Cpu and Video fans spin. There is no beeps coming from speaker though? It will not post into bios screen. Only things Attached are vid card, memory, cpu, and one hard drive. I have power to the main plug but not to the p4 plug. Even though asus recommends the four pin power to be hooked up, I do not think this is the problem and the power supply doesn't have the P4 power cable and plug coming from it. The vid card works in another system. Unfortunately I can not attest to the workings of the memory, I got given 2 x Asus P4T-M Mobos, one with 2xsticks of 128mb (each Rimm) and One with a single 128mb stick plus the C-Rimm sticks needed to fill the unused slots. One thing I did find curiuos was one of the mobos prefers it's "Clear cmos" settings on 2-3, (According to the manual 2-3 = Clear and 1-2 = default normal operation) otherwise it never wants to shutdown and restarts when I release the power button after 5 secs?
Any Ideas? many thanx in advance. Regards Ed. (21st March.2008).
Best Solution
posted on Mar 23, 2008
Helpful)
map9966
Rank: Guru  Computer Components  Expert
Rating: 89%, 1932 votes
Hi ed, that 4-Pin ATX_12 connector near the CPU is for powering the CPU. Suggest you change PSU's. Though I'd agree there are some boards that have the 4-Pin connector & it's not used. Those boards usually have a 24 pin main connector & lower voltage CPU's Please check here at Asus web site for P4T-M.
http://support.asus.com/download/download.aspx?modelname=M2A-VM&SLanguage=en-us
Related FAQ's P4T-M
http://support.asus.com/download/download.aspx?SLanguage=en-us
I'm sure your P4T-M will boot after connecting the ATXPWR, ATX12V. As you noted, it would be nice if you could test the memory. When you get display you can test your memory for free by downloading a mem test program at. http://www.memtest.org/
Enjoy the weekend Ed.
Mike
Comments:
Mar 25, 2008
- Hello again ed, your cmos is not abnormal. I have many manuals & your is one of em. Play it safe & move the jumper to pins 2&3 leave it there for 15 seconds or so. Than re-set back to pins 1&2.
Remove the battery as well & check it's voltage.
Guess I'm loosing my mind, I posted the incorrect Asus site for your boards. Try this link;
http://support.asus.com/download/download.aspx?modelname=P4T-M&SLanguage=en-us
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
compaq presario mother board, what should I replace it with
Answer
on automatic on mode when pugged at the wall outlet, continuous on mode, can't be put off
Answer
i want plant for ep-4sgm8i i want install to one other box and my sun has disconnect board
Answer
My webcam tells me that there is no video device,or my intergrated camera is not turned on,helen
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Motherboards:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
