Question about Mintek DVD-1600 DVD Player
DVD Player I was watching a DVD last night and working on my laptop while in bed. All of a sudden the volume cut off on my DVD Player (Mintek DVD 1600). I think I pressed a button on my Time Warner Cable Remote or Mintek DVD Remote accidently and now I can't get the volume to work for DVD only. It works on TV, but not DVD player. Can you help me please??????
  • tesiche May 15, 2008
    We had the same issue. We turned up our amp and could hear again, but only with the amp cranked all the way up--even then the sound was not loud enough for our taste and you could hear a bit of buzz because of the amp being maxed out. After some experimentation, we found that the problem is the signal going out from the DVD player. The DVD player does have its own volume control that can be adjusted using the remote control that came with it, and we have played around with that but it did not help much. The signal remains weak even when the DVD player's internal volume is maxed out
  • Anonymous Mar 23, 2014
    volume doesn't work on DVD player
  • 4 Answers
SOURCE:
"no disc" pops up when dvd is inserted into Mintek dvd-1600
The laser lens could be dirty. Try using a reliable CD/DVD lens cleaner kit like the Belkin CD DVD cleaning Kit but if that does not work the player could be defective or already broken. I would shop for a better-name brand player on eBay so that I won't spend too much on another player.
Aug 23, 2009 | Mintek DVD-1600 DVD Player
Mintek DVD-1600 Setup to cable box/tv
A dvd player that doesn't record hooks straight to the television, not the cable box. Tv's typically have av jacks. If yours doesn't, you will need to buy an rf modulator. If your tv has the jacks, U will need to use your tv remote and hit tv video or input or source on that tv remote to switch between input and tv modes.
May 03, 2009 | Mintek DVD-1600 DVD Player
Where can I purchase a remote for the dvd-1600 mintek?
You can purchase a replacement remote at the link below, for $27.99:
Mintek Replacement Remote Controls
An universal remote will work, but the codes may not be available. That can be a complication as you need to go through the remote programming procedure manually.
Better to buy the original replacement.
Feb 28, 2009 | Mintek DVD-1600 DVD Player
Mintek 1600 DVD Player
I don't have a Mintek DVD player or know anything about it, but their support URL is: mintek.com/subpages/001a_Login.asp
Feb 21, 2009 | Mintek DVD-1600 DVD Player
MINTEK 1600
Disconnect the Power Cord for 24 hours and see if that clears the problem.
Nov 22, 2008 | Mintek DVD-1600 DVD Player
DVD+R Wont Play in Mintek DVD 1600 Player
Kay what happens with some players is that they are only bulit to play a certain kind of disc. It also may be because the player is old. If you buy a new player it will be able to play all DVD's that you put in it.
Nov 21, 2008 | Mintek DVD-1600 DVD Player
Problem turning player on/off
I had the same issues, I disconnected the DVD player from the Power Source for 24 hours. Ours has been working well since then.
Nov 11, 2008 | Mintek DVD-1600 DVD Player
Mintek Passwords
I believe the password code is 88888. This is factory set this way and can be changed
Oct 20, 2008 | Mintek DVD-1600 DVD Player
Remote code needed
20839 is the DirecTV & Access HD universal remote code for Mintek, Shinsonic, & US Logic. None of which brands are listed in my Yamaha RAV283 remote code list (uses 4-digit codes).
20717 is also listed for Mintek by DirecTV. Other brands with the same code on DirecTV remote are: Apex, Blaupunkt, GE, Greenhill, Initial, KLH, Nesa, & RCA.
Of those brands, only Apex & RCA are listed in my Yamaha remote's list. I tried all of the codes for those 2 brands under types DVD, DVD Recorder, DVD/VCR, & TV/DVD. None worked. It appears to me that only those 3 brands for 20839 share the same remote code settings. If your remote doesn't support any of those 3, I doubt you will be able to use that particular remote with the Mintek DVD-1600.
I hope my research helps someone with this, as it was unfruitful for myself. Good Luck!
Jun 15, 2008 | Mintek DVD-1600 DVD Player
Mintek DVD-1600 DVD Player Logo
154 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Ekse
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
