Picture adjustment on zenith SM3247MK8
Top of picture and bottom of picture are not viewable. The sports scores or news streamers at the bottom and top are off the screen. How do I get the vertical adjusted
    Genius:
  • 1,550 Answers
Probablemente tengas problemas en el circuito vertical o los capacitores adyacentes hay que checarlos.
Posted on Mar 20, 2008
SOURCE:
Vizio tv settings
Check your aspect setting; ie: picture size, zoom settings
Nov 28, 2013 | Televison & Video
The picture is oversized and the printing as in the stock ticker or in the sports scores can only be seen a little bit on the bottom. Can't find anyway to resize the picture.
Zenith sets, like most others now, are adjusted electronically through a service menu. You'll need your original remote control (or a Zenith-brand universal replacement with a MENU key) to access the menu. Press and hold the MENU button until the channel number and time display goes away, then press 9, 8 , 7, 6, ENTER. This puts you into service mode.
In service mode, CHANNEL UP and CHANNEL DOWN move through the different settings, and VOLUME UP and VOLUME DOWN change the values. Make sure you write down the original value of anything before you change it so you can put it back if necessary. One of the reasons the manufacturers hide the service menu is because the set can be damaged by incorrect settings to some of the parameters.
On some models, you can't get to all the parameters unless you change one called F MODE from 00 to 01. You might need to do this on yours.
The list of parameters varies by model and features. I haven't worked on a Zenith in a long time so I don't remember exactly what yours says, but you want to find two settings for V SIZE (vertical size) and V POS (vertical position). Adjust the size first by lowering the value until the top and bottom of the screen are black. Then adjust the position so the picture is centered (black strips close to equal size). Finally, increase the size until the picture fills the screen again. It's normal to adjust for a little overscan, meaning you push the top and bottom a little bit out of view. If you stop too soon, on some channels you might see flashing lines at the top of the picture.
When you're finished adjusting, turn the TV off to exit service mode. If you needed to change the F MODE setting, put it back to 00 first. Your picture should be properly sized after all this.
Mar 19, 2011 | Zenith SY2772DT TV
46 inch sony picture too wide cant adjust with remote
If the Dish remote won't change the picture size when you use the "Format" button (either bottom left on remote or the "page up", "page down" buttons), then you will need to try the Sony remote. If the Sony remote doesn't have a "picture size" or "format" button, then enter the Sony User Menu and look in "Set up" for "Picture Size" "Format" or the like.
Hope this helps!
Jun 12, 2010 | Sony Televison & Video
THE PICTURE ON MY ZENETH PV6067DT TV WILL NOT GET
Make sure there is no light shining on the electric eye it will adjust brightness automatically also check bulb for dust and dirt
Nov 30, 2009 | GPS
The top of my picture is cut off.
Change the video output to wide screen
Oct 15, 2009 | Sony Televison & Video
Zenith Z25X22S 25" TV can't read scores at top or bottom
On the inside of the TV, there will be a knob with a RED cap on it, labeled vertial position. (it actually looks like a variable inductor)
With an allen wrench (possible 1/4) give it a half turn in either direction and see what happens. On the Z25x22S model, the vertical and horizontal position adjustments should be right next to eachother, but on the model i worked on, there was no variable pot for the horizontal position.
Hope this helps!
Jan 27, 2008 | Zenith Z25X22S 25" TV
Picture size won't fit screen. Can't see scrolling text at bottom (e.g. sports scores on ESPN)
hi there,
its probably not the tv but the set top box you need to fix. go to the settings and select the mode you want ie. widescreen 16:9 etc
then go to the tv and select the full mode or widescreen mode at 16:9
that should solve your problem. it takes some time to find the combination between the set top box and the tv to get it right
good luck
smeags
Dec 30, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Picture too tall. How do you shorten?
Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
Very low width and bowed verticals,no ew correction. R626 o/c
C630 (390nF, 300v) faulty, located next to scan socket. This fault can also be caused by R629 (2R7 fusable) o/c. In my set C630 was dry-jointed but not faulty. Check generally for dry joints in the E/W and PSU areas. Note that R629 is a safety component
Nov 23, 2007 | Sylvania SRT2432S TV
Sansui - BOTTOM OF SCREEN CUT OFF
Your problem is not a vertical alighnment or size adjustment. No, Im sorry to say its the old vertical output IC and /or the small capacitors around the ic and in the vertical circuit. If you dont have the right tools, like a soldering iron a multimeter know how to read a schematic diagram, then you should seek out a repair person to assist you in this repair.
Sep 12, 2006 | SansuiS2001 20" TV
Televison & Video Logo
230 people viewed this question
Top Televison & Video Experts
Ekse
