Laptop charger problems - Computers & Internet
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    ahuh? and what laptop are we referring to?
  • 54 Answers
Give the details?
Posted on Mar 21, 2008
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
Tip
How to troubleshoot a laptop charger.
  • Step 1 Wrap your charger's exposed wiring with electrical tape before proceeding. This will help to prevent any kind of electrical hazard or further damage.
  • Step 2 Push the wire next to the charger base (the connecting tip near the laptop end) side to side to see if you can get a current to connect. This is a temporary solution, but it can help you salvage your files so that you can work with them on a different computer.
  • Step 3 Make sure that it isn't a battery problem. Many laptop owners believe their charger is the problem when their battery is charging. Laptop batteries generally begin to lose the ability to hold a charge after two to three years of heavy usage. Try removing your laptop battery. If the computer still runs, the charger is not the problem.
  • Step 4 Check to see if the issue lies in your computer. You can do this by testing out an alternate charger on the laptop--if the charger still does not work, it's an internal laptop issue. For this kind of power system problem, you will probably have to send your computer to its manufacturer rather than a local repair shop.
  • Step 5 Replace your charger. A replacement charger is usually easy to find and quite affordable. Instead of going to a local electronics retailer where universal chargers can cost $100 or more, look online for your specific model's charger. Some chargers can be purchased for as little as $5
  • on Jul 21, 2010 | Computers & Internet
    Toshiba satellite won't turn on
    Before you make a decision about the next step, maybe you would like to know why the laptop charger is not working. Here are some commonly found reasons for this problem.
    You have been using the wrong laptop charger for your machine, or someone else has been using your laptop charger for another machine. This may seem like a harmless act, but it affects the battery on your laptop, and charger you are using as well.
    Your laptop battery has become weak and worn out from excessive use. Due to this the battery is not charging at all (or charging very slowly) when you plug in the charger. In this case there is absolutely nothing wrong with the charger itself.
    The wire of the laptop charger has got a distinct curve at one point, and this is restricting it from transmitting power. You need to look out for such bends in the wire, as this will ruin the efficiency of the charger in no time.
    This may sound elemental and stupid to some, but it does happen to many people. Maybe you are simply using the wrong laptop charger by mistake, or maybe you have failed to switch on the power switch. Check both these things to be sure.
    Any of these potential causes could be the reason behind your laptop charger not working. As a result of these, either the mains power lead of your charger may be damaged, or the power supply unit may be damaged, or maybe the lead itself is damaged or broken somewhere, or some circuitry inside the laptop is damaged, and not responding to the charger. It's hard to accurately tell which of these problems could be the real cause of your laptop battery not charging, without physically examining the machine.
    Solutions and Answers
    Now if you are well versed in computer hardware you can attempt to fix this yourself. Most people cannot do this, and it is advisable for them to visit a computer repair shop instead. They will examine the laptop charger not working problem, and suggest some suitable remedies for it. Depending on your budget, you can choose an option that suits you and simultaneously solves your problem. Here are some recommended solutions.
    Buy a brand new charger which will definitely solve your problem of charging the laptop for a long time.
    Replacement Toshiba Satellite M305 AC Adapter 75Watt 19V 3.95A
    If you're hesitant to pay that amount, you can try and purchase a second hand laptop charger from eBay.
    Get your's repaired and pay the repair shop the fees that they charge.
    If your warranty is still valid, you can simply get the laptop charger replaced.
    Reference: http://www.buzzle.com/articles/laptop-charger-not-working.html
    Oct 27, 2012 | Toshiba Satellite M305D Notebook
    My compaq cq40 laptop charger is not working
    • You have been using the wrong laptop charger for your machine, or someone else has been using your laptop charger for another machine. This may seem like a harmless act, but it affects the battery on your laptop, and charger you are using as well.
    • Your laptop battery has become weak and worn out from excessive use. Due to this the battery is not charging at all (or charging very slowly) when you plug in the charger. In this case there is absolutely nothing wrong with the charger itself.
    • The wire of the laptop charger has got a distinct curve at one point, and this is restricting it from transmitting power. You need to look out for such bends in the wire, as this will ruin the efficiency of the charger in no time.
    • This may sound elemental and stupid to some, but it does happen to many people. Maybe you are simply using the wrong laptop charger by mistake, or maybe you have failed to switch on the power switch. Check both these things to be sure.
    • Buy a brand new charger which will definitely solve your problem of charging the laptop for a long time.
    Compaq Presario CQ40 Laptop Charger
    • If you're hesitant to pay that amount, you can try and purchase a second hand laptop charger from eBay.
    • Get your's repaired and pay the repair shop the fees that they charge.
    • If your warranty is still valid, you can simply get the laptop charger replaced.
    Apr 25, 2011 | Compaq Presario CQ40 Series Laptop Charger...
    My laptop charging port is not working properly. My Charger is running properly but the charging port of the laptop is not working.It is not getting charged.Now the laptop is totally off and now i cant...
    There are three possible parts of the computer which cause the problem.
    1. ac adapter or charger
    2. battery
    3. motherboard
    The charger is working fine which leaves the battery and the motherboard to be the possible reasons for that certain problem. What you need to do is to check which one is really the part that's causing the problem.
    Here's what you need to do:
    1. Remove the battery from the laptop.
    2. Turn the computer by using the charger alone. If it turns on then, the battery needs to be replaced. If it doesn't then it's a motherboard problem which is a very complicated situation. You need to see a computer technician for a motherboard problem.
    Apr 19, 2011 | Compaq Presario CQ40 Series Laptop Charger...
    The cigar fuse on my 2011 Chevy traverse keeps blowing. The only things I am plugging in are m phone charger and my laptop charger. All of my collegues have the same vehicle and same phone and laptop...
    the garage is right most of the cig lighters r just for the lighters,they r not made for high amperage the Traverse has 12v power sockets made for this use them instead
    Mar 21, 2011 | 2010 Chevrolet Traverse
    I had problem while charging my laptop .when i connected charger to my laptop there was some problem and smoke started . i immediately removed my charger.can you please tell me is problem with my laptop or...
    where was the smoke coming out of the charger or the laptop? the problem is most likely the charger but if the smoke was coming from the laptop most likely your motherboard is fried.
    pease vote if this helps thank you.
    Feb 18, 2011 | Computers & Internet
    Acer aspire 5516 battery and charger problem
    Hi, this could be an unhelpfull suggestion but the charger may not be compatable with your laptop. Laptops notoriosly have different power settings, you may be forced to purchase a new Acer charger. Try ebay, you may be lucky
    Aug 01, 2010 | Acer Computers & Internet
    Computers & Internet Logo
    48 people viewed this question
    David Payne
    David Payne
