Monitor problems my NEC Multisync LCD 1830 monitor keeps cutting in and out or will not start at all on boot. Is it the montior or the video card?
    Genius:
  • 1,913 Answers
If u get normal beep of ram then check your disply resolution .
when u start your pc press F8 key continus then if u get menu choos best configuration loading in menu.then change your resolution to 800x600 or 1024x768 .if u not get menu and your cpu ;s smps still work but not disply on monitor then clear your bioss . get away the cmos cell for 15 minutes from its case.then start your pc .i think your problem is solved.
Posted on Mar 20, 2008
SOURCE:
NEC 17"1700M Works fine most
Either an overheating video-card, or a loose connection between the video-card and the monitor.
Jun 25, 2011 | NEC MultiSync LCD1700M (White) 17 in. Flat...
My monitor just started going black and white after a full colour boot. How do I fix this?
Hello, I would like to assist.
Please respond by pressing REPLY or LEAVE COMMENT
Have you tried a different video cable from the monitor to the pc yet?
Jan 13, 2011 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
My NEC MultiSync LCD 1765 monitor boots up to the lowest resolution available. When I attempt to correct the resolution through the Display Options in my Control Panel Settings, I set it at the highest...
Try connecting the NEC to a different computer, to see if it correctly accepts 1280-by-1024.
If so, then there's nothing wrong with the monitor, and the fault lies with either the video-adapter in your computer, or something messed-up with your installed copy of Windows.
Try replacing the video-adapter.
Dec 29, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
The resolution notifier keeps popping up (NEC multisync 1740 CX) and I am unable to turn it off.
It probably is warning you that your video graphics adapator is puting out a non-native resolution to the monitor.
LCD monitors are designed for a specific resolution. If you don't use that resolution, the LCD has to try to mimick the resolution you've asked for.
Check your display settings and also consider updating your graphic driver if a new version is available.
Oct 13, 2009 | NEC MultiSync 1940CX 19" LCD Monitor
Nec Multisync LCD 195VXM+ black screen after turning on computer
I'm thinking your video card is sending a signal the monitor doesn't recognize.
You'll need to start the computer and hit F8 until you get the black and white menu. Choose the VGA mode and it should work well enough for you to adjust the refresh rate or the resolution to get the monitor to work
Aug 28, 2009 | Computers & Internet
Touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
What cable do I buy
If it is a dvi monitor then you would need a dvi cable. VGA monitor would need a VGA cable. HDMI monitor would need a hdmi cable. If it is compatible with both dvi & vga and your video card has a dvi output then dvi is a better quality than vga. You can purchase the cable online at a store like cables2go. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | NEC MultiSync 1525X 15" LCD Monitor
It keeps cutting in and out sometimes it wont start period NEC Multisync LCD 1830
My 1830 did the same thing. I tapped the screen several times and it woke up. ???
Mar 20, 2008 | Computers & Internet
Intermittent display problem, NEC Multisync 1760NX
This usually happens when the resolution is set incorrectly for the monitor. If you have been using the same setup, probably an update changed the driver or setting for the video card. If it is a new monitor, try hooking up the old one and change the resolution to something the new monitor can understand. If you have been using it for some time and this is all of a sudden, then try to borrow a monitor and change the resolution to something the monitor can understand. If you borrow one and can get it working, also look and make sure the video card has a driver installed. Sometimes an update can change things.
Dec 21, 2017 | NEC MultiSync 1760NX 17" LCD Monitor
Open Questions:
Computers & Internet Logo
74 people viewed this question
Ekse
Alun Cox
