Question about Hotpoint HSM25GFRSA
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
The water dispenser is not working but the ice maker is working fine. What could be the problem?
my ice maker dispenses ice, but i can't get water to come out.  I already changed the filter.
Hi -
I am having the same problem with my Hotpoint side-by-side. Still have ice, but push to dispense the water and nothing happens. I have replaced the filter, and have tried to heat the crisper side wall - maybe I am not heating the correct area. Where exactly do you heat - or will that not work with my model. Any other ideas would be greatly appreciated!
  • 4 more comments
  • Anonymous Apr 08, 2008
    I have the same problem no water but ice works
  • jamesjcummin Aug 14, 2008
    I have the same problem with Hotpoint model HSM25GFR. Our power went out last week for about 12 hours. The water dispenser started working after the power came on but stopped about a week later. I have good water flow up to the quick disconnect fitting to the door so think the supply line inside of the door freezes up. I have experimented with the temperature control for the freezer with no luck. I believe the freezer should be at 0 degrees F so I don't want to raise the temperature too high. It seems many people have the same problem with Hotpoint and GE side by sides.
  • roddy66 Nov 05, 2008
    Water line is freezing up, repair man says replace door ~$600, I don't think so. Mnay people are having this problem, there has to be a fix....
  • jacobpleger Dec 30, 2008
    I am also experiencing the same problem with the water dispenser.
  • planecrazy Jan 11, 2009
    I found a fix on another webite. It is embarassing - but it works. If you insert a small piece of plastic tubing (like from a hairspray bottle or a juice straw from a capri sun-actually now I am combining one of each) into the water dispenser and blow hot water up into the water line - it will thaw out the line and you will have water again. Yes - you get very friendly with your frig! Anyway, it wasn't happening very often, but now the thawing only last a couple of days. So - I am going to try to take the inside door panel off and wrap the water line with insulation!? Wish me luck...
  • wrestlpsu May 11, 2010
    same thing is happening to us too !!! wrestlpsu@yahoo.com
Take the icemaker out and let it sit in the sink for around 12 hours. Then put it back in. This has worked for me when I have the same problem. I think that the water line is freezing up. I have to do this every month or two.
Posted on Jun 08, 2009
GE GSH25JFTA BB water dispenser not working but ice cube maker working fine
Ice maker is working. Water dispenser is not working. I did the initial diagnosis and the water line is not frozen. How do I replace the water valve or is that the right next step?
Jan 05, 2012 | GE GSH25JSTSS Stainless Steel Side by Side...
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Dec 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
I have the same problem, although mine is intermittent. Apparently it's a problem with the line freezing. For an excellent discussion of the issue, see http://www.askmehelpdesk.com/advice/t-14182.html
Dec 20, 2007 | Refrigerators
Hotpoint HSM25GFRSA Logo
250 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
