Question about Sony Cyber-shot DSC-W50 Digital Camera
Digital Camera Fault
Sony DSC-W50
Turn on power and the display screen states 'ACCESS'. The lens extends and retracts several times then the display states 'Turn power off and then back on again'. The same happens over and over.
Any suggestions would be greatly appreciated.
  • 2 more comments
  • Anonymous Mar 20, 2008
    my camera says access and to turn it on and off again. The lens goes in and out.
  • 112957 Mar 21, 2008
    I had the same problem sent it in to have it repaired under warrantee and less than 5 months later same problem - and I never dropped it.
  • sara jenissa Sep 21, 2012
    how can v fix this problem
  • Anonymous Mar 13, 2014
    When I press the power button, the lens extends and retracts three times and then I get a message to turn the camera off and back on, but it repeats the same problem. The battery is fully charged.
ACCESS error could happen when lens gets stuck but if it happens when lens moves back and forth without problem it usually means that where the lens assembly plugs into main system board connection is loose. These connections are held in place by a very small thin fragile plastic clip and a few drops could be enough to snap it but not do any other noticeable damage to camera. Camera would need to be opened to see if clip is broken or maybe cable just needs to me reinserted. Either way only open camera if no longer under warranty and you are somewhat handy
Posted on Mar 21, 2008
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
Oct 12, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
What is the answer to the problem "Sony Cybershot DSC W150, screen reads turn power on and off agagin"?
is not a joke........
Use a can of compressed air and blow around the lens while it is extended. Take a relatively firm approach with this problem slap the camera into your palm two or three times.
Not lens down in this case, but using the side or rear of the camera to make contact with your palm
Make sure you have the camera cord around your wrist so as not to lose it across the room.
Do this several times and turn it on and off till the message of tuen ona nd off no longer shows(if it ever did) and the lens retracts and works correctly. The compressed air will help remove any accumulated dust that is jambing the lens.
This is a sony tech fix and not a joke, they charge you $90 to do this and this fault is not uncommon in many of these small cameras
dust and dirt get taken into the lens bay ad eventually cause it to stick. Hence the use of comptressed air with the brutal approach
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
SONY DSC W300 SAYS TURN OFF AND POWER BACK ON AND LENS COVER NOT
Internal problem of mechanism of lens assembly. May be caused by grain of sand, or anything else, probably you will have to let it repaired.
Sep 18, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Screen says turn the power off and on again and lens stays out
Lens jammed & requires manually resetting.
If you are in the UK I can help you out.
p.m at kiddo242@hotmail.com
Aug 18, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Problem with camara
Lens isn't working and need to be replaced.
Jun 07, 2008 | Cameras
You don't have to disassemble the lens. My camera would lens extend , pause and then lens retract, pause again, then lens extend, pause and then lens retract. It would do this maybe 4 or 5 times before displaying "ACCESS" on the screen and then shut down completely.
Where the lens extends from the body is the area I am referring to, there is a tiny gap large enough to slide a sheet of paper into. That is the area I shot a tiny drop/burst of wd40 into. Wd40 is sort of electronic safe and most of it WILL evaporate.If you would like, send me your email address I will send a photo file-picture of how i did it. Hopefully it is the same problem.
jgbhornung@hotmail.com
Just put "camera problem" in the subject box
Jim H
Mar 30, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Lens stuck
Knocking the camera sounds like it works but may create another problem. I have had this problem with p-100 , p-200 and now the w50, I have found a small drop, of wd40 placed on both sides ,two opposing sides,of the lens ring where it extends from the body will work also. Don't spray, its a bit too hard to control amount deposited. Use a toothpick or a stick to dip and then drop the oil.
Mar 16, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Access Message
This is a hardware problem. Your simptons is tipical of a lens position sensor being faulty.
There is however nothing you can do yourself. Contact your nearest Sony dealer and take the camera to a Sony service centre.
They will quote you for a new lens assembly as they will not be able to replace the sensor only.
Cost should be about 1/2 of what you paid for the camera.
Good luck.
Feb 13, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cybershot DSC-W50
This is what sony cameras do when the lens has become jammed. There are multiple different reasons that the lens can jam but the result is the camera being unable to move it as expected and presenting that error message. Sometimes the lens can be manipulated gently (if extended at all) and freed from the jammed state. Failing this, disassembly is required. Check with your manufacturer for warranty service status and recalls. If they will not cover it you can find a repair provider online. David Millier Advance Camera Repair
Mar 10, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
My sony dsc-w50 camera won't totally boot up
It is a fairly regular occurance at our shop to see a Sony camera which, when you turn it on, extends and retracts the lens slightly several times and then says "turn the power off then on again". We were unable to find the cause of this issue for quite a while and ended up forwarding cameras with this problem to Sony for repair. Recently one of our techs found the issue to be a "lazy" focus motor. The motor was still functioning, however it was not functioning 100% and did not perform as the camera expected, causing the error. This is not necessarily the issue with your camera, but it is likely given how many Sony's we have seen doing this. If the camera is under warranty, definately send it in. If it is not, find another repair provider as Sony will charge you quite a bit for the repair. David Millier Advance Camera Repair
Mar 09, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
435 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
