Question about Xerox Phaser 8550DX Laser Printer
Error Code 09,038.46:103468 help!
Hey All,
I have the following error 09,038.46 and I need to find out the meaning of that issue. I've been stumped and can't find it. I'm new to this group so thanks for everyones help in advance!!
  • Gahprinters Mar 21, 2008
    Yaaaaa you are fixer!!! It was quicker with your help then another site I won't mention!!! I'm stick with this site as the much quicker response and very helpful!! Thank you
    Stay tuned for more posts
    President:
  • 2,072 Answers
That code is a back stick count failure.
You want to look in your ink loader, see if there is a stick jammed, twisted, broken or in anyother way out of place or hung up in the slot.
Be sure you loaded a 8550 stick also, since the shapes on the different phaser printer sticks are all different.
You may have to carefully remove the black sticks and reload them. You can take a screw and screw it into the ink stick, slide it back and remove.
Most likely you will find a gap in the ink sticks causing the problem. Here are the Xerox support page instructions.
  1. Open and close the Top Cover to resolve the problem.
  2. If the problem persists, arrange the ink sticks until there are no spaces between sticks of the same color.
  3. Check for non 8500/8550 ink sticks jammed in the ink load chutes. If non 8500/8550 ink sticks, whether manufactured by Xerox or by a non-Xerox ink vendor, caused the ink sick jam, contact support to place a service call.
Posted on Mar 20, 2008
  • Rick Kasper Mar 21, 2008
    Glad to help. And happy that's all it was.
E 35 diplay on electrolux e30ec70fss cook top
Hey Syl20 Bel, thank you for your post!
Based off the information you have provided your Electrolux cooktop is displaying an error code of "E 35". The error code means that the cooking zones could have a low voltage. This could be an issue within the filter board or power supply. You may want to seek help from a professional technician to help verify which component that would need to be replaced. A technician will have the appropriate tools needed to test each component as well as the knowledge to properly disassemble the cooktop. I hope this information is helpful to you. -Matt
Mar 07, 2016 | Electrolux E30EC70FSS Cooking Products :...
Start for just 1/3 second then stop with error PF ?
Hey Andy, thank you for your post!
From what you have described your Frigidaire dryer, GLEQ2152ES, is running for a few seconds and then displaying an error code of "PF". The error code of "PF" means there is a power failure and this could be an issue within your control panel or power source. I would suggest performing a reset, this could help clear our any miscommunications within the panel, and you can do this by disconnecting the power cord for at least ten minutes. I hope that this information is helpful towards your repair. -Matt
Feb 17, 2016 | Frigidaire GLEQ2152ES Electric Dryer
Why is door locked and will not self-clean?
Hey Kimberly, thank you for your inquiry!
I understand that the door on your Frigidaire range is locked and it will not start a self-clean cycle, it is also displaying an error code of "F91". The "F91" error code means that the door has exceeded maximum oven door unlock time. This means you could be experiencing an issue with your door latch, control panel, or a miscommunication within the range. To clear out a miscommunication within your range you need to disconnect power from it for at least ten minutes. I hope that this information is helpful to you. -Matt
Feb 11, 2016 | Frigidaire Gas & Electric Stove/Oven/Range...
What is error code e47?
Hey Ervin, thanks for your inquiry!
From the information you have provided your Frigidaire washer is displaying an error code of "E47". An "E47" error code means that the board thinks the door circuit is open in spin. This could be potential issue with the door lock or main control board. A reset could help correct this issue and to perform a reset you would need to disconnect power from it for at least ten minutes. We hope this information is helpful to some degree. -Matt
Jan 23, 2016 | Frigidaire Washing Machines
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
Power light is green than goes red
Hi beinhauert,
The symptoms you've mentioned indicated that the unit turned to standby mode. This is an indication that there's something wrong on the TV. To help us narrow down where the fault came from, please access the built in "Self diagnostic Screen". Follow the steps below.
In standby mode (red light is on), press the button on the remote control in sequence "Display", "5", "Volume (-)", "Power". Self diagnostic screen's displays its log of error. Please let me know the error code with corresponding numerical value "1" means error has been detected, "0" means no error.
Jdvillanueva
Jan 06, 2012 | Sony Grand WEGA KDF-60WF655 60" Rear...
What does error code 006-0803 mean it's the reason
This error may occur if there is a network maintenance or outage. Please click here to check our Network Maintenance / Operational Status page.
If you receive this error code, please try again.
If the issue persists, review your DNS settings, and update the settings to auto-obtain. [How to]
If this is already set to auto-obtain, you may try entering an alternate DNS, such as Google's DNS. [How to]
for more help visit CBR Tech Solutions
Dec 26, 2011 | Computers & Internet
HP Photosmart error code Oxc19a0002 what does it mean?
This error code indicate a failure in the ink system. If you've tried with different/working cartridges, please follow the instructions given HERE.
Good Luck.
Thanks for using FixYa.
Jul 17, 2011 | HP Photosmart 3310 Printer
NAND FLASH ROM ERROR - 2490MF
Konica before fixing the issue used to ship out the controller board.
Now a simple firmware upgrade will solve your issue
Aug 11, 2008 | Konica Minolta magicolor 2490MF Laser...
Xerox Phaser  8550DX Laser Printer Logo
199 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
