Question about Vtech 9009111 Cordless Phone
Vtech 6773 base id number?
Had my phones for 3 years now, and never had a problem...until we unplugged the entire phone system to switch it to another room, and now none of my phones work. they all say "enter base id." i went to vtech website, downloaded the manual for my model 6773, and it said nothing about a base id. their only solution was to unplug the base, take out all the batteries and then replace them...which, didn't work. does anyone know what or where i can find my base id???
  • 1 more comment
  • nickbabu Nov 14, 2008
    Same problem. I just switch hans sets. Still, I am looking for base ID.
  • r_nowack Jan 03, 2009
    I have the same problem. We unplugged the base and when I re-plugged it in, I get a message : enter base ID ##############
    I've tried everything and nothing seems to work. No the pager does not work either. This isn't right. I should have to buy new phones just because I unplugged it. They will be getting a piece of my mind tomorrow.
  • Charles Calloway May 11, 2010
    Strange. Can you page the handsets fgrom the base?
SOURCE: VT ip8100 - enter base id problem
24Ghz Vtech phones cant find base
Posted on Dec 21, 2008
  • 1214 Answers
SOURCE: can put in base id
Did you try this (from the i5801 manual) -
To register a handset to the base, follow these steps:
Step 1: If ENTER BASE ID is displayed on the handset, proceed to the next step; if not, press MENU on the handset, then press ▼ until REGISTER is highlighted; now press OK.
Step 2: Locate the 15-digit Base ID number by pressing, at the base: MENU, then press until DISPLAY BASE-ID is highlighted, then press OK.
Step 3: Carefully enter this number using the handset dialpad. If you make a mistake, press to backspace. When finished, press OK.
In a few moments, the handset will be assigned a number (1-6). This will be the lowest available number in the sequence not previously assigned to another system handset.
Step 4: Repeat the procedure for any other unregistered system handsets.
Reply back if you have success. The Base ID is not from the bottom of the base unit, but is something you get by following Step 2 above.
Posted on Feb 04, 2009
bestdarngood
  • 3037 Answers
SOURCE: i need the base id
It sounds like you are trying to register the handset(s) to the base. Once the handset is charged, if you see 'Searching for Base' on the display,(The bold is for your question specifically but I thought you may like all of the information for getting a phone hooked up) ON the Base unit press MENU, scroll down to Display Base ID, press OK, and the Base ID code will display. If NEW appears in your handset display, press the soft key under it and enter the base ID code you found in the base display. If 'New' does not appear on your handset, press MENU and then scroll down to REGISTER. Press OK and then enter the base ID code. If the handset is already registered, please deregister all then register again. To deregister a handset which is registered to the base model 20-2431, Using the soft keys on the base, press the 'MENU', then press the down arrow once until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 6 times, until 'DEREGISTER ALL' is highlighted. Press 'SET' . If your handset is registered to the base model 20-2481, Using the soft keys on the base, press the 'MENU', then press the down arrow twice until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 7 times, until 'DEREGISTER ALL' is highlighted. Press 'SET'.
Benjamin
Posted on Jul 11, 2009
  • 547 Answers
SOURCE: Phone is asking to 'Enter Base ID'. Where is base
You don't have to key in the ID, just put the phone back into the charging cradle of the base unit. It will then re-sync itself to your base unit's ID.
Posted on Jan 14, 2010
iandakin
SOURCE: i have a vtech i5853 base and 4 other phones and
sell me your base, mine broke but my phones seem to work. 613 912 1422 ian
Posted on Nov 04, 2012
How do I turn off the base ringer?
Should be a switch on the base itself include Make of phone and I might be able to tell you where at exactly
Apr 23, 2016 | Vtech DS6421-3 - cordless phone w/ call...
Phone are 5.8 ghz vtech
may be the frequency problem for noise problem.
pleaSE CHECK IT OUT.
ADJUST THEM AT SOME PROPER LEVEL..
AND THEN TRY.
Oct 18, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
My phone dials too fast. The only way I can dial a number is by taking it off the hook and manually dialing after I hear the dial tone. If I use Caller ID, redial, directory, or putting in the number...
I had the same problem with a model 6325-4. Worked fine for the first week. Then, tone dial with redial, directory, etc was too fast for system to register the number.
Called Vtech support. After a 15 hold, 5 minute explanation and tech listening to a reproduction of problem over the phone, she asked that I perform a complete system reset (I called via my cell).
I unplugged power from base first, then removed battery from all hand sets. Powered down for ~3 minutes (with tech waiting on line the entire time).
I powered up base first and then reconnected all handsets. Selected a handset at random and performed the same dial from directory test I had done just before power down. The thing worked again. Call went through just fine. Tried several other selections in directory with same positive results. Now, if the system just stays stable and working.
Hope this helps..
Dec 19, 2010 | Vtech CS62192 Cordless Phone
One 6041 handset will not connect, while the second handset does.
Unplug the entire phone set system from both electrical power and wall jack for approx 2-3 minutes and replug.
It's a reset measure that allows the entire system to reset / reboot as well as stops any and all line feed memory from the live phone line to hold the fault.
Such can be somewhat common when sharing the line with a DSL connection or wireless router is in use.
Jul 27, 2009 | Vtech Cordless 6041 Phone
Phones stopped working. They only read
first step is to unplug all power and phone connections from the wall for all Vtech phones and bases.
Second,plug each set and base in the wall for power one at a time.
Go back to the basics and pair the handset with the base of the unit.
Do this for all sets one at a time.
May 29, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
VTech 2420 handset will not promp me to key in the base ID
If the other three handsets work ok then you have a defective handset.
Mar 17, 2017 | Vtech VT 40-2420 Cordless Expansion...
Can put in base id
Feb 04, 2009 | Vtech i5807 (735078006394) Cordless...
I just got this phone VTech 5881. I plugged it in and have tried to register the handset. I can't. It has someone else's name in it. what should I do?
First, deregister all handsets:
Step 1: At the base, press MENU, scroll to BASE SETTINGS, then press OK.
Step 2: Using the base dialpad, enter * * 3 3 5 7 8 2
Step 3: Re-register each system handset:
At the base, press MENU, scroll to DISPLAY BASE-ID, then press OK. The 15-digit base ID number will be displayed.
Step 4: Using the handset dialpad, enter the base ID number. Repeat the registration procedure for each system handset. Each handset is assigned a number in the order of registration
Dec 13, 2008 | Lands Phones
Vtech 9009111 Cordless Phone Logo
493 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
