Question about Compaq Presario 5000 PC Desktop
Help me fix my pc please
When i turn on the computer, the light comes on and the fan starts but nothing else happens, no picture or anything and my monitor is working perfectly!! if anyone can help me it would be much appreciated!!
    Genius:
  • 1,913 Answers
Hi
put away your ram from slot start pc then if u get beep then your ram is ok. then clear your bios setup with hepl of cmos jumper settings. put away your cmos cell approx 15 minutes from its position.check also your processor clear dust .then start your system u get working sys.
bye
Posted on Mar 20, 2008
    Guru:
  • 147 Answers
It sounds like a cable is unplugged on the motherboard. Check all connections and be sure everything is pushed down firmly.
Please let me know if this helps. Take care, and good luck!
-Chimpster
  • Alexander Kogl Mar 25, 2008
    Has this helped? Please rate us. Thanks!
6ya staff
SOURCE:
Gateway dx 4320 wont turn on
It could be a few things:
a faulty power switch - you say that you've changed the PSU, but did that include the switch?
it could also be a Faulty Motherboard or CPU. If either of them are fried, you won't see anything come on either.
I'd suggest checking the switch first because that's the cheapest and easiest to replace
Sep 14, 2012 | Gateway DX432019 PC Desktop
Computer turn on, but when it does it won't POST
It seems like a motherboard issue. It heats up, thus is not able to turn on continuously. You may need to check internal parts embeded on the motherboard llike the fan and processor before you could know what needs replacement.
Jul 18, 2010 | Dell Dimension E521 PC Desktop
TOSHIBA A305-S6914 HAS POWER LIGHT BUT NOTHING HAPPENS
Sorry but something like that can't be fixed with internet help, you will need to take the computer to your IT person. you can try removing the batt and power for 10 seconds then start in with power only. other then that. you could be lookinf at faulty hardware + and that could be anything
Sep 12, 2009 | Computers & Internet
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Dell Inspiron 530 I turns on and nothing happens
1.) If when hitting the power button, ABSOLUTELY nothing happens, no fans come on, nothing- You need a new power supply most likely. I see this all the time in my shop. Here's the bad news- Dell likes to use their own special power supplies, so a normal one may not even fit in the case. If that is the case, then I'm sorry to say Dell likes to charge over $100 easily for a new one.
2.) Fans come on, lights come on, but no screen. This can mean any number of things. Bad VGA cable (or DVI), bad RAM, bad mobo, even a bad PCI card. time to start troubleshooting. Change what parts you can, remove any PCI cards that are not needed, remove one RAM card then the other, etc....
Apr 29, 2009 | Dell Inspiron 530 Desktop Computer
Computer won't start up and has a constant tone.
If the noise is constant then it means the problem is either:
1: a Power supply issue
2: a motherboard issue
3: a keyboard problem
the latter of the three being the easiest to fix, try booting with your keyboard unplugged or even better if you have another keyboard try using it to see if that corrects the problem.
If the above does not work then you have a problem with 1 or 2, and in order to find out for certain you will need to test it, you can goto your local computer diagnostic store to see if they can check which it is.
and hope its not a problem with the motherboard.
Hope this helps, and Good Luck
Apr 13, 2009 | Computers & Internet
Power light comes on but nothing appears on monitor
Mostly your heatsink damaged your motherboaard. check caps lock LED and Number Lock LED are working after switching on. If not ur motherboard or processor get damaged and u had mentioned what happened. Ur heatsink shorts some circuit in  your motherboard
Apr 06, 2009 | Compaq Presario 5000 PC Desktop
ATX power on Motherboard not working
Just to check the voltages coming from the psu. However if your old psu is doing the same it must be something else. Did you try it without the graphics card? and is it the fan in teh psu which is spinning up?
My next port of call would be any other expansion cards, followed by the memory modules. Take them all out apart from one memory module and try to boot.
Also check that the pins from the power button are connected correctly. you can also try starting the pc by touching the two pins together with a metal tipped screw driver.
Dec 16, 2008 | Gateway GT5032 (827103078121) PC Desktop
Emachines model T1862 WILL NOT START
There are a wide range of possibilties. first if nothing at all happens when you press the power button. (no lights no sounds etc.) then the most obvious culprit would be a dead power supply or a switch in the back thats off.
Are there any fans or lights?
Please let me know...
Jan 17, 2008 | E-Machines T1862 PC Desktop
Compaq Presario 5000 PC Desktop Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
