Question about Vacuums
My remote control has broken (stoped working) where can we get a replacment remote control. TV - Goosmans - LD3761HDFVT
    President:
  • 1,673 Answers
Sometimes you can go to the manufactors site and order direct thru them. Otherwise you will have to have a repair shop get it for you.
Posted on Mar 20, 2008
I have a rca universial remote control and I lost the manual and cant program it for my toshiba television I need the code and directions how to program it
Not knowing the code, you'll have to do it using the Automatic Code Search method.
1. Turn the TV ON manually.
2. Press and release the TV button on your remote. The illuminated ON-OFF button will turn on and stay on.
3. Press and hold both the TV and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
4. Release both buttons after the ON-OFF button turns back on. The button should remain on.
5. Press and release the PLAY button. You may have to do it several times. Be patient.
If the TV does not respond after five seconds, continue to press and release the PLAY button every five seconds until the TV turns off.
6. Just to check the code is right, after the TV turns off, press and release the REVERSE button then wait to see if the TV turns on again.
If that works, you've got it!
Press and release the STOP button to save the new code.
May 24, 2011 | Vacuums
The base is not sucking ,only the hose works
is the beater bar turning ???if not belt broken if so tube from beater bar to hose stoped up
Apr 11, 2011 | Hoover Vacuums
My hunter ceiling fan is not working and according to hunter technical support, I need to replace the remote control receiver (part # 8511204000) at a cost of 50.00 plus shipping.is there a way to by-pass...
If the product did not come with a manual control on it then yes you will have to use the remote. However, if the replacement remote will cost nearly as much as the ceiling fan itself you could simply purchase a new fan.
Feb 28, 2011 | Vacuums
I have a Hampton Bay Midili fan which I just installed about a month ago and it was working fine. A few days ago when I flipped the switch on the light flickered on and off consistently until I turned the...
in many of these remote controlled lamps you cant use the new spiral light bulbs .. you can only use standard incandescent lights .. if thats not the trouble then you may indeed have a bad controller (in the fan) .. there is probably at least a 90 day warranty maybe as much as 3 years .. make sure the wire nut power connections are secure inside the fan.. if one of the the wires in the fan are not making contact then you will see a similar problem .. once in a while i have seen strong external RF signals interfere with the controller but thats rare and usually doesnt last long ..
i would : 1. check all the connections .. 2. replace the light bulb to make sure its not flakey or the wrong type .. 3. try to get the fan replaced in warranty ..
Jun 06, 2010 | Vacuums
I have a dyson - bought it 3 yrs. ago and the roller brush stoped working - doesnt pick up anything. Can you help? The brush doesn't roll or spin. Where can we take it to be fixed and is it under warrenty?...
Don't worry it's probably just that the belt has broken or stretched. Your actually supposed to change them yearly. So if its been three years thats probably the case. Here is a link to the belt you need and a manual with instrutions:
Dyson DC07 Belt and Manual
Nov 28, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brushes stoped turning I cleaned them off still nothing
The belt that drives the brushes has broken or come off.... look in your manual for instructions on replacing the belt.
Aug 15, 2009 | Vacuums
The beater stoped working .
That sounds like a bad or burnt contact between one of the connections in the hose. Make sure all the connections are secure and look at the contacts, if they are bad you will usually see burn marks or melted plastic.
Hope this helps, and let me know if it doesn't.
Dec 01, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Hoover carpet cleaner
Take the brush block out, is the shaft that goes up into the turbine there, or is it broken off. If gone, then replace the brush block. If there, then probably the turbine isn't working, this is what drives the brushs. It may be just clogged up, you can remove the turbine, take it apart and clean it out real good and put it back together. If it works, then you are set, if not, then it will have to be replaced.
Mar 24, 2008 | Vacuums
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
