Carrier 52PQ307 Wall/Window Air Conditioner Logo
Posted on Apr 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Home air conditioner not cooling but service agent tells us need gas filling, is it correct
Anonymous
Level 3:
  • Master 1,515 Answers
  • Posted on Apr 16, 2010
Anonymous
Master
Level 3:
Answers
1515
Questions
Helped
628546
Points
4388
Hi, if you had a certified company tech, or contractor come out and check this unit with his gauges, he would know if it has lost its charge. Most window units have no service valves on them to check the freon gas. He may have installed a bullet piercing valve to check the freon. I would have to agree with him. To be sure, I would have to make the checks myself. This says you have a leak in the system somewhere. That would need to be checked and found also. If it was a service tech you called and want to get it fixed, I would use the same guy.
Sincerely,
Shastalaker7
  • Anonymous Apr 17, 2010
    Hi, why didnt he charge the unit when he was there? Most window units they want to remove and take back to the shop. Please let me know where you stand.
    Sincerely,
    Shastalaker7
Why is there no cooling from the air conditioner?
With my Fujitsu installation the engineer turned a valve on the outside unit to release the gas. But don't forget you have to pressurize the system with Nitrogen first and test for leaks, then use a vacuum pump to get all the Nitrogen and air out of the system before letting the gas in. It is a job for Pros, not the home handyman.
Mobile air conditioner not in car but in home is not cooling
Make sure the filters are clean and the fan is working. You may need to have it serviced.
The unit is not cooling, is there a service centre on Central Coast NSW Please
go yellow pages for your area and check for air conditioners service and repairs
read all the adds and there will be one that lists as authorized service agent for your make of air conditioner
go to a retailer and asks who is the service agent for your make of air conditioner
you didn't list what make it was so try this
go google and type in --authorized service agent for ( make of air conditioner) in NSW---and pick a agent that is closest to your address
I have a 2006 chevy uplander a/c stopped working spent $1000.to fix still no cool air checked cabin filter and vent doors all ok.Then replaced the a/c compressor and still no cool air.$1400 I spent ev
Usually cooling gas is missing, go to some car AC service and fill it. Do it in short, otherwise could damage be higher and in meantime keep AC switched off to prevent damage. Call more services for better price.
Our ac inner fan is moving but it isn't cooling
If AC is correctly set to Coll mode, then cooling gas is missing, call some AC service in near and fill the gas. Ask for price first. Do not switch on AC until this is done, to prevent higher damage.
My air conditioner cooling coils get frozen approx\.after 2 hrs of running i have showed it to the service boy they first serviced filled gas and even changed the fan motor. but still the problem...
Hello, the evap coil will freeze from either low airflow or low charge. I would clean the coils, check air filter and replace or clean if dirty. If you have a thermometer measure the air entering the ac and the air leaving the ac, the differance should be 15-20 degrees, measure this after cleaning the coils. If it still is below 15 degrees the unit is underchraged.
Maytag M6X08F2A air conditioner is not cooling, working as fan
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
How do you replace the cooling agent? Is it Freon based?
Must be done by licensed technician. Gas must be reclaimed and requires special equipment to recharge. But it is a normal procedure, however, it should be checked for leaks if it is losing its charge.
2helpful
2answers
My air conditioner will kick on but will stay on and not
The thermostat is not functional, therefore its not cutting off the compressor once the room air gets cooled to the temp setting of the thermostat, also the refrigerant gas may have leaked out some but not the entire refrigerant gas(freon, CF4, etc.), keeping the compressor running contentiously to come down to the set temp..............sodeep
Top Carrier Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
