HELLO I HAVE GOODMANS LD1945WD 19" HD READY DIGITAL LCD TV AND ITS SUFFERING FROM LIP SINK ISSUES,THE DISPLAY PICTURE FALLS OUT OF SINK BUT IF YOU CHANGE CHANNEL AND GO BACK THE SOUND AND PICTURE GO BACK INTO TIME PERFECT FOR A FEW MINS.I HAVE BEEN TOLD THIS IS A DTV ISSUE AND A SOFTWARE UPGRADE IS AVAILABLE BUT HOW DO I GET THIS? I HAVE TRIED THE UPGRADE OPTION ON THE TV BUT IT SCANS AND DISPLAYS THAT THERE ARE NO UPDATES AVAILABLE SAT THIS TIME?
  • Anonymous Feb 26, 2009
    I have exactly the same problem and scanned for updates, but there has never been one available. Can anyone advise?
5 Suggested Answers
SOURCE: Sony 53" XBR
Have you tried adjusting teh convergence using the remote control? See the owners manual. Appears you might need to align 2 of the 3 color guns (usually blue and red) to the cross hatch pattern.
Posted on Oct 20, 2007
chrispurs1
  • 372 Answers
SOURCE: lost picture on LCD TV
Hi.
Your problem is very lightly to be A faulty invertor pcb.
Relatively easy to replace but you may find it difficult to purchase.
The invertor pcb basically makes high voltage to strike up the tube lights behind the screen.
What make & model is your tv set & what country are you in.
http://dysonmanuals.llc.nu/
Chris..
Posted on Dec 30, 2007
  • 579 Answers
SOURCE: SAMSUNG 19 INCH HD READY WIDESCREEN LCD TV LE19R71BX/XEU
We will need a list of the everything you tried.
Usually, this kind of thing is caused by hookup errors.
Posted on Jan 01, 2008
Astrobyte
  • 110 Answers
SOURCE: Picture gone from TV Model LE46M51B
I suspect that your backlight has gone out. If you shine a light on the screen can you see remnants of the picture that should be displaying? If so, it's definitely the backlight, and most likely the power inverter for the backlight. You can probably find a replacement inverter, but you may need a repair manual to install it. I'd recommend checking the warranty status first and sending it in for repair if you can.
Posted on Feb 17, 2008
SOURCE: LCD TV LA40A650A1F. TV/DTV
samsung advised  atv/dtv selection by that button not available on australian series 6
Posted on Sep 23, 2008
Remote control code for a 19"HD READY DIGITAL LCD
Hi Hazel,
The common codes used for Matsui TV are 098 and 178, however if these codes didn't work, please let me know the exact model number of your universal remote control to determine the right/other codes.
Kind Regards,
Mjsazon
Dec 16, 2011 | Universal Remote Control 10694 Remote...
I have a Goodmans 19"
TRY AND RETUNE .THIS IS DONE IN THE LCD MENU
Sep 12, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
Hi there i have a goodmans gtvl19w19hd 19inch tv and just wonted to know if it has freeview on it any where as i can not seem to access it if it has it ....
Hello. I've just acquired one of these TVs. There is no freeview on this model. However there are Scart and HD connections so it's easy to plug in a freeview or FTA Satellite receiver.
Jul 11, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
I got a samsung le32 tv i got sound but no picture can you help please
Connect your TV to a DVD player. If there is still no picture, it means the display inverter of your TV is defective.
The display inverter is what makes the TV brings picture. Since the TV is no longer bringing any picture, the display inverter is the first thing that needs to be checked as it is most likely the cause of the problem.
Please give me feedback if you need any assistance in locating or identifying the display inverter.
Your sincerely.
Elect_Comp.
May 16, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sound but no picture
Connect your TV to a DVD player. If there is still no picture, it means the display inverter of your Tv is defective.
The display inverter is what makes the TV brings picture. Since the TV is no longer bringng any picture, the display inverter is the first thing that needs to be checked as it is most likely the cause of the problem.
Your sincerely.
Elect_Comp.
May 13, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
No picture problem on Philips Flat TV 37PF5321 37 in HDTV-Ready Telvision
I am suffering from the same problem. When I turn on I get sound but no picture, although I do get the backlight coming on when I turn it on, I then get about 1/2 a second of picture then nothing. Even if I select TV specific functions such as the menu, I get no menu screen come up.
Any ideas out there?
Jan 09, 2011 | Philips 37PF5321 37 in. HD-Ready LCD...
I have just got a goodmans LD2271D HD ready digital lcd tv and for some reason it wont tune any help? i've been to the menu and selected auto tune and it still says no service.
This usually means poor signal , HAD THIS PROBLEM WITH MY MOTHER IN LAWS TV, Take tv to other aerial point in another room ( i brought mother in laws tv home to my aerial ) and do a retune,
This could sort things out.
pete
Nov 09, 2010 | Goodmans 289NS 14" TV
HD Ready or not ????
if it was mislabeled at the time of sale then you can return the tv. 480p only allows progressive scan to be used. 720 is the min hd you can run.
May 01, 2008 | Televison & Video
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
Electro Med Services...
