I am unable to get the scanner part to work with my computer. It tells me that everything is installed correctly but when I scan an image, it comes back blank. Need help, before I throw it out the window. Please.
I need a hendheld pen scan
suitable for XP and editable on word,
to save especially half of the...
(More)
to save especially half of the lines not the all page,also it should write-
I need wireless one,with large memory,which can run on batteries I can recharge on the USB port.
do ou reccommend anything please?
I m going to use it in Europe
on Bugarian and Turkish
thanks a lot
One image appears stuck on a page. We could not get rid of it so she shut down Ascent Capture, shut...
(More)
One image appears stuck on a page. We could not get rid of it so she shut down Ascent Capture, shut down the scanner, shut down the Scan Station computer. When she turned on the scanner and opened Ascent Capture, she got error messages - unable to initialize - cannot locate device. We repeated the shut down process, confirmed hardware was connected securely, same result.
I've uninstalled and restalled software. Swapped connection from USB to SCSI and reinstalled on...
(More)
I've uninstalled and restalled software. Swapped connection from USB to SCSI and reinstalled on another computer.... same problem. In black and white mode to scan with image size of A3 or A4 - half of the image is smudged on top and bottom. If I use greyscale the smudge is a little lighter -- if I use color mode, smudge is light but you can still see it.
