Question about Intel Motherboard
Wi-fi and sound problem
Have win2k on iwill xp 333r sound sometimes is either distorted or no sound after booting up even if rebooting several times. though sometimes the sound is present after booting and is of good quality. have installed all the latest drivers i can find though i think there may be newer ones but cannot find them. also a similar problem with usb wi-fi adapter which seems to load perfectly but except no internet connedction and ip numbers are not 192.168 ect but the auto ones you get when when you have no network.
any help would be appreciated
many thanks for your time and effort
andrew
  • Anonymous Mar 22, 2008
    i want my motherboard free download websites
Cxvcdvc
Posted on Mar 22, 2008
Drive is not reconized
Hello impurrfect,
Since you have completely removed the drive from the computer, remove the CMOS battery(big watch battery) on the motherboard for about 30 seconds then reinstall the battery, then reboot. This time however, when you press the power button to bootup, you need to start tapping F2 about 2-3 times per second to access the BIOS. If the F2 key does not work, try using F1 or maybe even the Delete key.
BIOS screenshot: yours may look a little different but the concept is the same.
http://drivers.softpedia.com/get/BIOS/Iwill/Iwill-XP4evo-Bios-105a.shtml
Once in the BIOS go to BOOT or BOOT DEVICE, something to that effect and see if the drive is listed. You will also have to reset the system time while in BIOS so now is a good time to do that as well.
Regardless If it IS or ISNT listed, go ahead and exit the BIOS and choose YES SAVING CHANGES. Your PC will now continue to boot into normal mode. Once in Normal Mode, go ahead and go through Shut Down and once shut down, reinstall the drive and hopefully the PC will recognize it as a new device. Then you can visit the manufacturers website for firmware updates.
Jul 10, 2009 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
Award BootBlock V1.0
Hi.
The BIOS (Basic Input output System) on your motherboard has become corrupted and the computer can't boot normally. The Bootblock is a "failsafe" device that allows the computer to boot far enough to use the floppy disk drive, even though the rest of the BIOS code is scrambled.
How do you think this happened? The most common cause is people trying to "update" the BIOS and messing up the flashing process. Sometimes some particularly nasty viruses can wreck the BIOS code as well.
Now this might be fixable. You will need to download a known good BIOS from Iwill's website and the Award BIOS flashing utility. Then you will need a bootable floppy disk (DOS) to start the computer. You will have to copy the BIOS .BIN file over to the floppy beforehand and the flashing utility. There will be information on the Iwill website on how to flash the BIOS.
Here is a full detailed webpage on how to go about all this:
http://pages.sbcglobal.net/jefn/bootblock.html
I just did a quick Google search using the motherboard details you provided and came up blank ....
If you can't get the BIOS flashed and usable again then I'm afraid it's time for a new motherboard/computer.
Dec 30, 2008 | FIC AZ 31 Motherboard
Integrated Sound & Video not working on my XP4 Mini PC
I have xp4 evo system , i have driver disc that came with barebones unit i could send you copy , JOHN...
Nov 19, 2008 | Iwill XP4evo Barebone
Asus k8v-vm motherboard rebooting problem
this is your bios battery put new one in and it should work
Nov 18, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Audio files for IWill DP533
Try this
Download Microsoft UAA drivers uninstall all other sound driver and install the UAA ones and reboot
On reboot go to device drivers and update your sound drivers. will go on net to find and install them
A lot of on board sound nowadays require the UAA drivers before and sound can be recognized
Most times doing this works occasionally it does not
I have had sound that says it need one make of driver and would not work with it tried a different ones and it did
If the UAA drivers combined with your sound driver do not work give others a try.
Nov 04, 2008 | Iwill DP533 Motherboard
Phillips go gear SA3245 reboots win 2k computer
You must have Windows XP SP2 or higher for it to work properly - there are no drivers, nor was it designed for earlier versions of windows
Jul 24, 2008 | Philips GOGEAR SA6045 MP3 Player
I'm trying to set up a Linksys Wireless A G card with an old Gateway Solo 5300 laptop. I use the same card with both a Dell Inspiron 8100 and 1501 laptops without problems. My network is setup using...
The old standby solution was used: I removed the card from the laptop and rebooted the computer without it. Then I re-installed it. I then checked the configuration and saw that it had not changed the network encryption to WPA-Personal from WEP - even though the card had shown that it had. So, I changed it again, and voila! - it worked. Can't believe that after working with these damn things for so many years, I can still get tripped up by the simplest solution...
May 22, 2008 | Computers & Internet
ATI Radeon HD 2400 PRO - Win2k drivers
You can download a beta version of the driver for Win2k HERE
You could also download the ATI Catalyst Drivers Version 7.2 for Win2K/XP if you want from HERE
Hope that helps..Not sure if the CD in the box contains the software for Win2k though...
Apr 18, 2008 | Computers & Internet
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
