Question about Palm TX Handheld
Palm TX not powering up
My Palm TX was fully charged, and then all of a sudden went off (black screen. I did a reset and it would come on briefly and then it would power off again. I tried to reset it again, and it did the same thing. Now, a reset will not even work.
  • audrey1312 Mar 31, 2008
    i'm having problem with my TX handheld too, bought in nov 2005. just fully charged my handheld after not being used for a week as it was totally flat out. after fully charged up, i can't open any file in the Documents. each time i select a file, the screen will go all black, and the thing gets reset. other applications work fine. help!! anyone with bright ideas?
  • sceeter Jun 13, 2008
    mine is doing the same thing. replaced battery, from one of those cheap imports, and worked for awhile, now doing the same thing again. wont pwr up unless hard reset and then the screen just fades away.
    Problem Solver:
  • 5 Answers
Your Palm will auto-off after 30 seconds to 3 minutes of not using it, depending on the auto-off setting. If that's not it, you may have conflicting software installed. I had a lot of software installed on mine before and it got to where it wouldn't come on. I had to do a hard reset by holding the power button in while pressing the reset button until the screen comes on. This restores the device back to original state. You will have to reinstall all additional software that you want to add, but it will take care of the conflict. If that doesn't work, then the battery is probably no good, or the device is no longer functional. Hope this helps.
Posted on Apr 03, 2008
My 5 yr old Palm Tx suddenly started trying to
I did a warm reset and it worked. Just hold the up key and reset!! good luck
Aug 29, 2009 | Palm TX Handheld
Hard rest plam tx
Here are the steps to do a hard reset. Best wishes.
1. Press and hold down the power button.
2. While holding the power button, use the tip of the stylus (or similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your hand held.
3. Wait for the Palm Power logo to appear and then release the power button.
Aug 18, 2009 | Palm TX Handheld
Palm tx wont turn on
When the battery is discharged, it is best to charge it overnite.
Have you reset the TX?
Hold the power button down and push in the reset button on the back of the TX with the stylus. Hold the power button down until you get the screen where it ask you if you want to erase/reset the unit. click yes to reset.
Then when it comes back up, re-sync it with the Palm Desktop on your computer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 17, 2009 | Palm TX Handheld
Palm will not turn on
have you tried a hard reset?
Todo a hard reset, First press and hold the power button, while holding the power button use the tip of the stylus to gently press and release the reset button. wait for the logo to appear then release the power button.
when you see the message that warns you about erasing all of the info on your hand held press up on the 5way navigator to finish the reset
Dec 21, 2008 | Palm Tungsten E2 Handheld
Problems
This can happen if the application is corrupted.  Try downloading a new copy and added the new program to the Palm desktop installer progam.  The battery should be fully charged as well before performing a new installation.
Oct 23, 2008 | Palm TX Handheld
Palm Tx problem after hotsync
I had the same issue, the palm is stuck in a loop,
I got mine out of this by pressing the power button while the palm was on the screen where the bar goes across the bottom, it asked me if I wanted to erase all data, I said yes, and it reboot normally, I went thru the setup, and all is o.k.
I did have to try this several times, but it eventually worked. Hope this helps, although it looks like this is an older question. I hope you have resolved it.
Oct 12, 2008 | Palm TX Handheld
Phone Wont Turn On
unfortunately, you'll have to do a master reset on your phone. You'll loose all of your data. TO do this.. power off the phone. Then press the center select button (silver button on navigation pad) then power on the phone while keeping the sliver button pressed. You should get a Master reset prompt.. click Yes.
Apr 11, 2008 | Motorola Mobility Moto Q
Palm tx
try removing the battery or doing a warm reset ie plug it in and pusg the reset button.
Jan 29, 2008 | Palm TX Handheld
White screen with vertical bands
I have experienced the exact same thing. No dropping the Palm. No moisture. Just turned it on at work and it had the lines. Fortunately the data was still available for a synch. Now I am ordering a complete LCM and digitizer from PDA Smart.com. See http://www.pdasmart.com/palm-tx-repair-parts.htm for the pricing. It isn't cheap, but I believe it will fix the problem.  Let me know what solution you came up with and how the issue is now. Thanks, er
Aug 27, 2007 | Palm TX Handheld
Palm TX Handheld Logo
119 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
