Question about Refrigerators
Samsung fridge freezer rsh1dtmh1/xeu
Leveling Problem
hello
I have just had my fridge freezer
delivered and am trying to level it.
The rear of the appliance is 12mm
lower than the front when resting
on its wheels on a level floor.
The only adjustment I can see are the
feet at the front, these would only make
the problem worse.
Should I raise the rear wheel on a piece
of wood.
I would appreciate any advise you could
give me.
Thankyou
Richard
  • 1 more comment
  • Anonymous Apr 07, 2008
    i removed the wheel at the front this allows the feet to be adjust more
  • lake214 Apr 07, 2008
    thanks for the advise. I think you have come up with the best solution.
  • Anonymous Mar 17, 2014
    I have an LG fridge model LMX21986ST just delivered. The levelling instructions refer to the levelling legs at the front of the unit. The unit is much higher in the front and these legs will only increase the slope. The problem seems to be the front wheels are much higher than the back wheels . Is there a way to adjust the wheels?
The only way is to remove the middle wheel right at the front this allows adjustment with the 2 feet at the front
Posted on Apr 07, 2008
Hi I have a samsung fridge freezer. Sl39wj1/xeu. Doesn't seem to be doing anything no light but is continually flashing f5
not sure what you mean water in fridge and ur assuming? did it freeze everything or not freeze? is fan not running or compressor? any noise or sounds?
Mar 14, 2015 | Samsung Refrigerators
I have a samsung twin cooling fridge model: RS21NCSV power: 230V/50Hz model code:RS21NCSV1/XEU [A] temperature is playing up!! Freezer is working no problem. The fridge is getting cold but not cold enough...
You almost certainly have a problem with either defrosting or evaporator fan motor. Please verify your model number so I can pull up your unit to provide troubleshooting information. Thank you
Mar 26, 2013 | Refrigerators
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
My Samsung Freezer isnt working but the fridge is fine
without checking equipment you can only assume things that may go wrong...1st..try fully defrosting complete unit,clean all vent/drain holes then switch back on and let unit do its thing for 24 hours.then check temperatures are minus 18-20c for freezer and plus 2-5c for fridge (approx)unless you have electrical meters to check, this is just about all you can do..
Feb 19, 2010 | Samsung RS2630SH Side by Side Refrigerator
NO WATER COMING OUT OF WATER DISPENSER ON MY SAMSUNG RS21DCNS/XEU
you either have a kinked water line, or a frozen one. There is a possibility that the solenoid isn't working.
Nov 08, 2009 | Samsung Refrigerators
Hi i have a fridge freezer which is a samsung sl39wj1/ xeu and i need help coz it keeps coming up with f5
water in fridge on shelve from freezer.( I am assuming) Have defrosted and cleaned fridge and freezer removed all visable ice and water. Took off vent in fridge no ice. what else can I check out before calling repair man?
Dec 31, 2008 | Refrigerators
Fridge is not level - it is higher at the front than at the back.
We had the same problem when our was delivered last week. I spoke to Samsung customer services.
They said the roller in the middle of the front is not meant to be there permanently. It is just a transport roller and should be removed once your fridge freezer is in place.
To remove it:-
- unscrew the two white plastic feet at either side of the front until they touch the floor.
- then place a flat end screwdriver in the slots in the feet and continue to unscrew them. They will start to lift the front of the firdge -freezer up until the front roller no longer touches the floor.
-keep doing this (a little bit each side at a time so the fridge -freezer stays level) until the roller is about 15mm off the floor.
- then get a small flat spanner and remove the two small bolts on the metal plate that holds the roller to the bottom of the fridge-freezer.
Once these bolts are removed the roller and plate will drop to the floor and can be removed.
Then using the screwdriver, screw the feet back in until the point when the front of the fridge-freezer is level with the back.
The whole process shouldn't take you longer than 15 minutes.
I asked Samsung why this isn't included in their instruction manual and they couldn't give me an answer which I thought was poor.
I do wonder how many Samsung RSH1 fridge-freezers are out there with the front roller still attached!!!
Oct 25, 2008 | Freezers
Refrigerators Logo
903 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
