Question about Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher
Dishwasher not pumping the water out?
Frigidaire Ultra Quiet III; Mod # FDB750RCC1 (2 yr old) Dishwasher isn't pumping the water out of the bottom. Took the components out of the bottom, cleaned everything, re-ran it -still not working. Pulled it out of the cabinets, emptied out the water, put it on its side. Took smaller filter pump (at back corner) off found a small piece of glass. I think maybe the bigger pump in the middle of the dishwasher isn't running? Hoses also clean. (Don't hear a pump running during any of the cycles?) What suggestions can you give me. I thought maybe a hammer, chainsaw. (just joking) I'd appreciate any help...
  • 1 more comment
  • Ichiban01 Apr 01, 2008
    Just wanted to say "Thanks" I bought the drain pump new ($35.00) from an appliance dealer locally. It works great. I figured it was the drain pump, I just wasn't sure which motor it was. I've never had to work on a dishwasher. It saved me $$$.
    Thanks again,
    Bonnie (Ichiban01)
  • jenemery71 Nov 12, 2008
    My dishwasher will not drain the water. There is nothing clogging the line b/c we took the water out and all of the pieces at the bottom if the dishwasher. Where can I get the motor/pump for cheap? The dishwasher is 3 years old... or should I just get a new dish washer.
  • my3sonsznn May 12, 2009
    I have standing water in the bottom of dishwasher. I did take the filter out of the bottom of the dishwasher and found all kinds of grit. I am guessing from the dishwashing product that I am using. Any ideas oon how to get it the access out of the dishwasher?
  • 53 Answers
Hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
Posted on Mar 21, 2008
Will not drain water from Ultra Quiet III dishwasher?
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 25, 2010 | Frigidaire Dishwashers
My frigidaire gallery ultra quiet III dishwasher does not spray water within the barrel case; is my surge pump gone?
Yes Yourr Pressure pump that does teh high pressure spray is not working. Now identify the wires to the pump and check the voltage during the cycle .If present the pump is faulty and must be replace. However if there is continuity on the coild ccheck to see that a reset can make it work from a strck up condition.
If there is no voltage on the pump the controller unit is faulty.check relay , check board..
Sep 17, 2010 | Dishwashers
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a frigidare gallery ultra quiet III that is approximately 10 years old. It is not draining water to the point that it is leaking on the kitchen floor.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | Frigidaire Dishwashers
Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
Aug 30, 2009 | Frigidaire Dishwashers
Dishwasher not cleaning the dishes
have you cleaned the fliter in the bottom
Feb 15, 2009 | Frigidare FGB24S5DC Gas Single Oven
Fridgidare ultra quiet III
how old is this unit and what is the model #?
Feb 13, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Frigidaire Ultra Quiet 111 - ground up dirt on dishes
Remove the bottom plate near the floor. You can then look in under the dishwasher machine. The feet are adjustable up/down with a wrench most of the time. The dishwasher machine should tilt slightly away from the over flow sensor. In this case, Frigidaire Ultra Quiet, the rear feet should be lowered, or the front feet raised. If you have a machine with the over flow sensor on the bottom, at the back, tilt your machine slightly forward. Use detergent that dissolves food proteins. Problem solved. If you care to reward me, put a small symbolic sum to paypal account carolehel@aol.com
Feb 07, 2008 | Dishwashers
Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher Logo
1,132 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
