Sony Cyber-shot DSC-W130 Digital Camera Logo
Posted on Apr 16, 2010
I dropped my digital on the floor. It sony
I dropped my digital camera on the floor.Now when I turn it on I can hear the sound but lenses won't come out
Anonymous
Level 1:
New Friend:
  • Contributor 47 Answers
  • Posted on Apr 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
47
Questions
0
Helped
15124
Points
87
Your battery (or batterys) could be loose, just check up there
let me know if this helps :), oh and also, have a look at my photos! http://finnsharp.daportfolio.com/
1helpful
My camera lense won't go in. Everytime I switch it
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
2helpful
After my Nicon coolpix S570 has dropped on the floor, the lens does not work and when i turn on the camera, i hear a noise and get a message for lense error.
you have stripped the lens gearing you will find that you need to have the lens gogs replaced a very expensive repair sir. it may be time to buy a new one
sorry
take care
may you and yours have a happy new yr
My Friend dropped my DSC-W30 camerashot on brick floor (it was nocked off a not very high table) and now when I try to turn it on.. the lense just comes out then half way in then out.. (it looks liek a...
unfortunately the camera is non repairable short of dropping it again in hopes it jars the auto focus alignment back into position. this is a one in a million shot , but what have you got to lose.
1helpful
I have a sony DSC-W170. It was dropped and now
I had exactly the same problem with my Sony Cyber_Shot. Here is what I did and the problem was fixed. I cleaned around the lense. While I turned the camera off, I pressed down the lense very softly (some up and down motion). After a couple of times, the lense retracted almost completely. Then I pressed a little harder until the lense retracted 100% as normal times. I turned it on everything was back to normal. If the lense does not have mechanical problem, you should be able to do what I did.
If there is no mechanical problem, most likly some dirt got on the sides of the lense while it was open. Try keep it very clean always.
Good luck;
1helpful
Camera dropped and lens is stuck one day i tried to make a video on my camera but then it fell and now the lense is stuck and when i turn it on it wont come out and when i turn it off it wont close
this may sound drastic but, grab the lens and try manualy realigning. If you hear a grinding noise the lens assembly has to be replaced. Flat rate from sony is usually pretty reasonable. Hope this helps.
1helpful
Sony cybershot 7.2 When you turn it on the lense comes out and goes in and comes out and goes in on and on and on till you turn it off.
this is a lens array problem probably due to the fact you have dropped it down to floor. the only thing you can do is take it to nearest sony service center and get the lens array replaced. it costs aroung 60$.
1helpful
Sony Cyber-shot w120 digital camera won't pop lense out
Your zoomunit is defective. Rotronica has replacements for this camera.
Or contact your Sony repaircenter.
Regards,
Rob NL
2helpful
Lens won't in on camera and makes clicking sound.
When you dropped your camera, some dirt got on the outside of the lense or some mechanical part of the lense broke or dislocated. If some of the mechnical part of the lense is damaged, you need to open up the lense from the camera and inspect the parts. Look for loose parts, then clean it and put it back.
I had the same problem with my sony Cyber-shop, but it was not dropped. somehow one or more small piece of dirt got on the outside of the lense. Here is what I did and the problem was fixed for good.
While turning the camera off, I pressed on the lense (up and down motion) softly. After a few times, the lense retracted 95% of the normal retracted position. I then, pressed the lense a little harder in untill it was fully retracted. It has been working okay since then.
You should always keep the outside of the lense clean and do not drop it.
Good luck
Cybershot
Haha, I have the same problem.
The lense is stuck.
I kept turning it on and off repeatedly.
And now I can view pictures on it again.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
