Question about Durabrand PDV-705 Portable DVD Player
Cant load disc
One morning my dvd player was working but by the afternoon when i tried to put it on for my 2year old. the disc wold not load. and then it says disc error or no disc. can somebody please help me its only 6months old. really dont feel like buying a new one. thank you.
  • 1 more comment
  • Anonymous Mar 20, 2008
    yes please help i have debuged it to the laser going to far off the disk but how to factory reset this thing i dont know
  • twink2072 Apr 15, 2008
    When I load a disc into player it spins half way and reads no disc Help
  • lkerber Aug 11, 2008
    I have the same problem. It worked find last time I used it and tonight when the disc was put in it would not load and kept saying "no disc".
    I have a klh digital dvd player model # kd-1220
I was having the same problem with my pvd-702...I genlty cleaned the lens with a dap of alcohol on a q-tip. I blew the lens so it was dry and the dvd player started working. No need to try to call the 1-800 number, it is disconnected and the warranties are not valid, because the address does not exist. try the q-tip, it worked for me.
Posted on Mar 30, 2008
When trying to play a DVD, we insert the disc and it says loading. Then it tells us that it is the wronge type of disc.
your disk and player must be compatable, you cant play dvd's in a blue ray player, you cant use blue rays in a dvd player, you cant use ps4 games in an xbox and you cant put cd's in a record player... hope that helps!
Jan 03, 2016 | Televison & Video
'No disc' message on Samsung DVD home theatre system
hello,
the problem the disc is samsung DVD home theatre is having is the lense that is weak. if yo replace the lencse then it wold work properly.
Jan 04, 2010 | Kenwood DV-6050 Multi-disc DVD Player
''Wrong Disk'' error
KM,
You'll need to check the region code of your player.
Make sure you have no discs in the player, and unplug the unit.
Plug it in and turn it on.
Open, then close the tray (with no disc!)
Press the Setup button, then select Load Setup
Press the Enter
While it it loading, press Menu.
When the box appears with a number, confirm it says 1 (region code 1 = USA). If it doesn't, please change it to 1 using the Up / Down buttons.
Press Enter to accept the change.
Jul 07, 2009 | TruTech DV288B3 DVD Player
I HAVE A SAMSUNG DVD HR753 WHICH HAS 160 HARD DRIVE
Make sure you are using the right disk IE, DVD-R or DVD+R. Most Newer DVD player's will play DVD-R but very few play DVD+R
Jun 23, 2009 | Toshiba SD-6200 Multi-disc DVD Player
Always says bad disc
Try to clean the DVD lens using a lens cleaner.
Feb 16, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dvd recorder - dvd+rw disc loaded - now stuck on load
turned off the dvd recorder at power outlet. Left overnight. Turned on again in morning and pressed open/close and managed to get the dvd drawer to open. No further problems
Jun 01, 2008 | Pioneer Televison & Video
Car DVD Player not working
hi sounds like its not reading your discs. try giving the dvd a clean and maybe try the DVD cleaning disc.
otherwise next stop repair agent.
Mark
www.blueice-electronics.co.uk
Feb 23, 2008 | Car Audio & Video
DVD player says "no disc"
replace the player because laser lens is probably burnt out.
you can get a new player for 30 bucks at target or walmart
Jan 15, 2008 | Samsung DVD-V4600 DVD Player/VCR
Says Bad Disk
I WENT BACK LATER, ROTATED THE DISC ABOUT HALF A TURN AND IT LOADED. TOOK IT OUT PUT ANOTHER IN AND IT LOADED JUST FINE ALSO. MAYBE IT WILL KEEP WORKING OK.
Oct 27, 2007 | GPX D1816 DVD Player
"No Disc" Error
cleaned your lens with 100% cotton buds, if not work again change the laser eye. do it!!!
Sep 09, 2007 | Polaroid PDV-0701A Portable DVD Player
Durabrand PDV-705 Portable DVD Player Logo
108 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
