Question about Garmin StreetPilot 2620 GPS Receiver
Can I change the hard drive in my Garmin 2620 to flash memory? My 2620 does not have a flap on the side like the 2610.
    Scholar:
    New Friend:
  • 39 Answers
I believe bot of the answers from Romesz and Shaun_ST are incorrect. The 2GB Cornice brand microdrive uses a 20-pin custom ZIF and isn't ATA. There doesn't appear to be any converters readily available for purchase and the drives are less than readily available in April of 2010 than they were in 2008. However, without some kind of converter to connect to your PC you will not be able to format the Cornice drive so that the Garmin can use it. The Garmin 2620 without the CF card was a big product manager error. On a side note, to use a new emerging, proprietary product like a Cornice 2GB hard drive over an established and widely used CF card medium is a huge lapse of judgment from a product management perspective. Cornice has since gone out of business and are not making any drives that will provide a service option for you and Garmin has discontinued out of warranty service as well.
Posted on Apr 28, 2010
  • 22 Answers
I am working on changing out the cornice drive, the problem is, in one part that the hard drive is permanently installed, but could be removed because it is only connected with a ZIF cable. But the to connect a CF card you need a cable adapter that is available on eBay. Of course the CF card could not be that easy to remove because there is still no card slot on the unit. I don't know if this would work with the other electronic components. But not in possible to do it.
Posted on Mar 23, 2008
  • 3 Answers
No, it seems like its soldered in there. I took mine appart to check it out hoping i could take it out, connect it to a computer with a special cable, and Copy it to a bigger drive using (Ghost) or somthing, then putting it back in.
I wish Garmin would make it easier for you back up the hard drive and made it easier to swap the drive out if you wanted to.
Posted on Mar 22, 2008
SOURCE:
Where can I get a new 2.2 GB magicstor hard drive
There are many different compatible CF cards for the removable CF version of the 2620 that will work. A search of "Garmin 2620 CF" will yield what you are looking for for around $15.
Mar 08, 2010 | Garmin StreetPilot 2620 GPS Receiver
I have a garmin streetpilot 2620 that does not work well is it worth fixing
no, you should update to the newer Garmin Nuvi, much faster acquiring sats and a lot easier to type in addresses.
Oct 27, 2009 | Garmin StreetPilot 2620 GPS Receiver
Garmin StreetPilot 2620 totally dead
For the problem you are experiencing it is unlikely the time and effort needed to be spent trying to repair the product will be worth it compared to purchasing a used replacement 2610 for around $60. However, if your touch screen and accessories work you may wish to sell them on a third party web site for spare parts for others. You could fetch as much as $30 depending on what you have. If you have a remote and bean bag mount those alone can catch up to $30 + shipping.
Oct 02, 2009 | Garmin StreetPilot 2620 GPS Receiver
Garmin streetpilot 2620 in demo mode
Do you have any unlock code for your unit? Delete this code "demo" from MapSource and put unlock code for your unit and try to download to unit a small part of maps.
Nov 12, 2008 | Garmin StreetPilot 2620 GPS Receiver
Replacing maps
You cant... Garmin sucks at support for doing stuff like this. They want you to buy a new one instead, only to find out its obsolete in a few years and then your new one is not supported in lets say in the year 2010.
That is why the Flash model 2010 and 2050 were more popular. Gave users more options and less moving parts for there unit to break.
Jan 01, 2008 | Garmin StreetPilot 2620 GPS Receiver
Garmin 2610
This seems to be a common problem. Garmin says hardware failure. Someone says clean around the edge of the screen with an electric razor brush. Try this and let us know.... See other problem posted elseware Same problem....
Nov 20, 2007 | Garmin StreetPilot 2610 GPS Receiver
There is no reset button. Every time you turn off your Garmin and turn it back on it reloads everything fresh. What is likely the cause of what you are experiencing is a failed Cornice microdrive. It is near impossible to fix with the parts available today (May 2010) and it is more time management and cost effective simply to purchase a working 2610 from a third party site, or to purchase a new unit from the store that is still supported. In addition to the parts issue Garmin discontinued Map support for the 2620 (and 2610) in 2009.
Oct 14, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin Streetpilot 2620
Most likely your hard drive is gone bad. Push "menu+find" buttons then turn on, you will get diagnostic screen, it will show if your cornice drive is bad. It will say"Cornice Dive removed"4f3efc6.jpg
Sep 23, 2007 | Garmin StreetPilot 2620 GPS Receiver
GArmin 2620
In February I posted that I will replace the cornice drive on my 2620 because I had this problem 019d1f6.jpg Well I did that, but could not fix the problem. Garmin is asking $275 to replace my unit, I did not wanted to pay them that much. So I bought a 2610 at eBay for a $100 and don't have to worry about hard drives any longer.
To get this screen on a GPS push "menu+find" and then turn on unit. It will show this diagnostic screen.
Jul 06, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin 2620
still no fix, trying to find the original box so i can hook it up to the computer
May 29, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin StreetPilot 2620 GPS Receiver Logo
164 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
