Question about RCA D61W20 61" Rear Projection Television
D61w20 big screen tv
I DISCONNECTED THE BLUE TUBE AND MY TV COMES ON AND STAYS ON.WANTING TO FIND HOW TO INSTALL NEW ONE
What does a blue tube look like
Posted on Mar 22, 2008
  • RCA Master
  • 8,617 Answers
You will need the service manual to be able to properly align the new tube after installation, that will also give you important info such as discharging the old tube as well as removal instructions. Post the chassis number on your set and I can post the link to get a good service manual if you would like. rca are crossed by chassis number that should be located on the tag next to the model number
Posted on Mar 20, 2008
6ya staff
SOURCE:
Set comes on with a blue screen with retrace lines,then shuts down. Turned down screen control on flyback, set stays on cannot control brill
The set is shutting down because the picture tube is been over driven, it is most likely the picture tube has a short in the blue gun, turning down the screen control drops the voltage to a safer level. The only other possibility is a short video driver and open feed resistor usually located on the video board on the back of the picture tube.
Feb 23, 2011 | Sony KV-32S40 32" TV
RCA D61W20 Image Turns on and Off, Rat Droppings
im sure that the rodent contamination is the root cause of your problem. but the blueish stain does it look like a smear? if you that is most likely a phosphur burn in the face if the CRT. it cannot be fixed without replacing the CRT. i suggest living with it or putting tv on the side of the curb.
Apr 06, 2008 | RCA D61W20 61" Rear Projection Television
TV goes out
pyrosp4,
it maybe you blue crt (picture tube). mine turn blue and then shuts off. i got it repaired for 460. 300 for the part 160 to install. you can try to adjust the voltage settings behind the speaker screen and see if that clears the problem. if not its you blue crt.
pridah
Dec 18, 2007 | Sony KP-65XBR10W 65" Rear Projection...
RCA television 20" TV/DVD C231 new, no picture, only stays on 15 sec.
This happened to me. Unplugg the TV and let it sit idle for ATLEAST 20min.  Remove the rear cover of the TV. BECAREFUL NOT TO TOUCH THE TUBE OR COMPASITOR THERE MAY TIL BE POWER TO IT!  You should see a (3) prong wire that is black+white+and grey. That wire is most likely disconnected. You will see where it plugs into the board.
Dec 13, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
Sony big screen tv not playing picture after 5 minutes or so
You have a bad picture tube, or perhaps a picture tube drive problem.. To see what is bad, remove the front speaker grill under the screen in the front. Remove the screws that hold on the board that covers the front. Insidfe this set, WITH THE TV SET UNPLUGGED< Locate which one of the tubes is the blue one. Gently pull off the board from the end of the picture tube and swap it with the green tube right next to it. The green tube is always the middle tube. If the blue comes up again, then the blue tube is bad and you will most likely be better off to buy a new TV set. If the green comes up as the bright one, swap back the boards, call a tech and tell them there is a CRT driver board , or an RGB drive problem. This should not cost you an arm and a leg to get repaired. Good Luck, and let us know how you make out with the repair of this TV set.
Nov 11, 2007 | Sony KP-46WT500 46" Rear Projection...
Repair of my big sony screen tv
DTD1363-CAR
Mine does this as well, I would really like to know a fix or if anyone has had any luck with getting theres replaced
Sep 08, 2007 | Disney DTD1363-CAR 13" TV/DVD
1998 mitsubishi big screen tv model vs-50603
Good Day, bigjim;
No inner tube. The tube may light up but it no video bias to turn the tube on, or the tube is so gassy that it doesn't emit properly.
It sounds like you will be in the market for another TV, because it sounds like like the CRT may be bad.
Hope this was helpful and not tooo late.
Good Luck, big IRISH.
Dec 30, 2006 | Mitsubishi WT-46805 46" Rear Projection...
RCA D61W20 61" Rear Projection Television Logo
211 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
