Whirlpool,cabro 2007 washer model wtw6400sw2
A green wire front right side screwed on the inside, was broken when taking off the top don't know where the other end goes. thanks
    Sergeant:
  • 351 Answers
Green normally is an earth wire.you dont really need to worry about it.
Posted on Mar 21, 2008
SOURCE:
How to Replace a Dryer Door Switch on a whirlpool
First, make sure the peg on the door that pushes the switch is in place and the two snap pegs that hold the door shut are not broken. If any of these are broken, replace them first and see if that solves your problem. If not, here's how to replace the door switch: Unplug the dryer. Pull out lint screen. Remove two screws revealed underneath. Slide a 1" putty knife between the top and cabinet at the top front corners on each side, jamb it in while tugging the top forward to release the clips, one at a time. Lift top and lean against wall. If it's a gas dryer, remove lower front panel and loosen two 5/16" hex head screws for top front panel. If electric, loosen same screws at bottom of front panel. Remove two 5/16" hex head screws holding front panel from inside near top. Carefully tilt front toward you, holding drum in place. Lift front panel slightly to disengage bottom screws and remove. Gently lower drum until it stops. Unplug two (sometimes three) wires to door switch on right side. Now the front panel is completely free. Remove two Phillips head screws holding door switch onto front panel. Reassembly is the reverse of disassembly. Make sure wiring to door switch is secured to cabinet so they don't drag on the drum, and are not pinched. Be careful realigning the drum into the door opening so felt seal is inside the front glide ring on the drum. After the front panel is in place, gently hand turn the drum to make sure it is turning properly and the belt in still hooked to the idler and motor pulleys. If the drum falls off the rear rollers, or the belt comes loose, you will have to correct it before putting the front panel back on, as you cannot reach them otherwise. Taking pictures during disassembly will help get it back together properly. It really is not as hard as it seems, you may even be able to replace the switch without removing the front panel. Also, if you have a three wire switch, write down where they go or snap a picture. If it's a two wire switch, it doesn't matter, it will work the same either way. Good luck.
Feb 18, 2014 | Whirlpool 358409 Washer/Dryer Screw &...
Whirlpool duet tumble fresh 4.4 F28 code?
F28 code with no red light showing for the locked door. The washer would lock the door and then become stuck in the locked position. I had to reach up and pull the latch release manually to get it to open, but then the same thing would happen. I eventually could feel another wire was up inside there and not connected to anything. I had to remove the top of the washer along with the door and door trim ring. Then removed the front control panel (the front panel swings out from the left side and is more or less kind of hinged on the right. Dont swing it too far just enough to pull it straight out after the left side is 4 to 6 inches out. Leave it plugged in and set it on top of the washer) I then removed the screws to the steel front panel that is around the door. Remove the latch and pull it out the right side just enough to get at the broken wire and the clip it came out of. I soldered the wire back onto the clip and reassembled the washer. It is working great now. Hope that helps someone else. I was almost ready to buy some expensive parts that would not have fixed the problem in my case.
Oct 02, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Need to get inside to reattach a hose...how do you get the side off
You do not take the side off. 1) Unplug the machine. 2) At the head, or control panel, find the two screws that hold it to the case. Some are on the left and right front lower corners of the panel, and some are vertical facing s on the rear left and right side. Also on some models they are in the front but you have to pull the end caps off the sides of the control panel. Further more in some of the newer models you have to take a thin paint scraper and slide under the left and right normers to press the clips in to release. 3) Remove the 2 screws and then pull the panel from the lower part of it towards you and roll it backwards. 4) Disconnect the lid switch connection in the the middle where the two grey wires and the green wire block connects to the body of the machine, usually near the middle under the panel. 5) with a flathead screwdriver pop out the two brass retainer clips on the right and left side. 6) Open the lid slightly where you can grab the case, not the tub, just the case, and pull forward and surprise!!! You just took the complete top, sides and front of the machine off.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 28, 2012 | Maytag Dependable Clean Top Load Washer,...
My whirlpool washer won't drain and spin. It is 10 years old. Fix or repair? Please say fix!!!
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. You can usually look and visually see the spot where the switch should be and if damaged. How to repair :
1) Unplug the machine. 2) At the head, or control panel, find the two screws that hold it to the case. Some are on the left and right front lower corners of the panel, and some are vertical facing s on the rear left and right side. Also on some models they are in the front but you have to pull the end caps off the sides of the control panel. 3) Remove the 2 screws and then pull the panel from the lower part of it towards you and roll it backwards. 4) Disconnect the lid switch connection in the the middle where the two grey wires and the green wire block connects to the body of the machine, usually near the middle under the panel. 5) with a flathead screwdriver pop out the two brass retainer clips on the right and left side. 6) Open the lid slightly where you can grab the case, not the tub, just the case, and pull forward and surprise!!! You just took the complete top, sides and front of the machine off. The lid switch will be attached to this portion so located it, remove the two screws that hold it in place, under the lid, and swap out with a new one. This is a cheap repair, just take your time and you'll be fine,
May 08, 2012 | Whirlpool Washing Machines
Washer does not drain or spin. don't know how to release the plastic release latches to access the lid switch.
On that stack washer/dryer the wayto get to lid switch is
remove diagonal panel between washer and control panel
in the back of washer top will either be 2 brass colored clips or in the very back egde of top will be 2 5/16th inch hexhead screws
for clips place a small screwdriver in front of that clip and pop clips off and slide top forward
for the screws remove screws from behind top in the left/right corner..pull top forward a bit and lift up a little the plug for the lid switch will be in front right side..squeeze the release for that plug,unplug swicth plug then remove top
in both cases lid switch asm. will be on right side of top on the underpart of it
Gene
Aug 23, 2011 | Whirlpool LTE5243D Top Load Stacked...
I have a Whirlpool top loading washer model # 8525079. It is leaking out the front bottom, also will not agitate or spin, and will not empty. Any ideas on what could be and how to fix it?
lift the lid,do you hear it clicking,if not you have a broken lid switch,for the leaking,if it's in the right front sounds like the pump is leaking,take out the 2 screws that hold the top console in,they might be in the back of console corners,lift up the console,now remove the 2 clips with a screw driver and remove the lid switch wires,now pull up and forward and remove the frame,you can change the lid switch and check the leak,the wire you disconnected for the lid switch,get a piece of wire,srip off the two ends and stick it in the outside holes on the harness that plugged into the lid switch,your just jumping it out so you can put the washer into spin to find the leak,hope this helps,if you need any more help let me know
Feb 22, 2010 | Whirlpool Washing Machines
Does the front panel come off?
If this is a Whirlpool Duet such as the one you posted this question under, yes, the front panel does come off. It can be a bit tedious, but these are steps required:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser drawer and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There may be a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. You may have to prop up the front feet of the washer for better access (a 2x4 works well for this). With the screws removed, the panel will drop down and come off. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
Is there a reason why you need to remove the front panel? If you need further assistance, please let me know. I hope this help you.
Feb 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool dryer heat up. But does not spin.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Check for belt on drum half way back on the drum running from left to right. If belt is missing or broken replace with part number 341241 later in this process.
Looking down inside dryer on left and right see a 5/16" hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Rotate front panel to right to get it out of the way watching to ensure wiring is not damaged.
Place new belt over drum groove side down if old one was broken. Check white idler pulley for free rotation before installing in holes of floor under motor pulley. Replace with part number 691366 if rotation of pulley is not free or if it appears worn. Loop belt with ribs inward and pass through the open space in the idler arm below pulley then pass loop over motor pulley rib side down. The configuration at the motor should now look like the Whirlpool model in the image below:
Belt and pulley configuration
Grasp front edge of dryer drum and rotate counterclockwise slowly to align idler and motor pulley and to remove any twists in the belt.
Reverse disassembly process to re-assemble.
Sep 06, 2009 | Whirlpool Dryers
Whirpool twin washer & dryer lte5243dq3 drum off center
The ltw5243dq3 is a top loading washer with the dryer stacked on top. In order to remove things
1. One the angled piece of metal that is between the dryer and the washer there will be two screws. Remove them.
2. Next open the washer lid. There will be two screws on the right side. Remove those.
3. Close the lid. There are two final screws that hold the top part of the washer in place. You can't see them directly from the front so you might need a mirror or access to the back side of your unit.
4. Slide the top of the washer forward about 1 inch. List it up about 1inch and you will see that some wires are attached. Disconnect these wires so you can take the top off entirely.
5. To remove the front panel there are two screws. One on the left and one on the right. If you look down inside in the washer you will see them.
6. Slide the front panel upwards and then you will be able to remove it.
You should now be able to see inside your washer and it should look like the attached picture.
hope that helped,
mishkin
Mar 29, 2009 | Whirlpool ET8CHEXSQ Dryer
The top of washer
take down the front acess panel that divides the washer from the dryer in front,,,but if you can get behind it theres a green metal clip on the rright and left ,right behind the back of the top remove those two screws than slide forward ,,remove lid switch connection on front left hand corner...its off,,,att; always unplug first
Dec 08, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
139 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
