Mitsubishi VS-60805 We have a Mitsubishi VS-60805, the picture went balce, with sound about a month ago. We took it for repair and was told that both transformers were out. Only one of the transformers is available from Mitsubishi; the other is no longer in production. It is 6 years old. Any suggestions on how I can salvage this TV? I really can't afford a new one at this point. Any help would be appreciated. H Brooks
  • 8,617 Answers
Which transformer do you need. i have a source for alot of mitsubishi parts.
Posted on Mar 20, 2008
Mitsubishi VS-60805
What you probably see is a burning area due to Cooling Fluid leaking from one of the CRTs. If this is the case, It is not worth fixing in my opinion because the Board would have to be replaced and the leaking CRT would also have to be replaced. The availability of the Board is doubtful Due to it's age. You can check at 1800-553-7278. This is Mitsubishi's parts department #.
Hope this helps,
Skyassoc
Jul 17, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS60805 screen
If I can't get my 60805 working properly again I may soon have one :-)
I'm located in Orange County, CA, so if you're close I may be able to help you out.
Jun 16, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Where can I get good E2PROM settings for Mitsubishi VS-60805?
I have this model and just got it working again. I have a Service manual also. But unsure about checking my settings
Jan 30, 2009 | Mitsubishi VS-60805 60" Rear Projection...
No picture but sound
I had the same problem with the same model. If you pull the cover off the speakers in the front , then the small black panel. looking from the front past your lamps are the 3 main boards, the r/h board has wire jumpers connecting to the center board. The set that is closest to you had a bad/loose/corroded connection on mine. All I did was resecure connection(try moving them with your fingertip) and turn TV on and check.
Jan 17, 2009 | Mitsubishi VS-60805 60" Rear Projection...
The Picture on my Mitsubishi vs-60805 "shrank" then disappeared
it isnt worth it, your verticle diflection is out, that board is about 3-4 hundred, and you would probabily need a service center do it(messing with like 30000 volts)and they will probabily charge around 200
Jan 07, 2009 | Mitsubishi VS-6041 60" Rear Projection...
No picture or sound just three low beeps
Hi guzzman2,
I have the same exact TV as you and it has the same problem. I took the whole tv apart and checked the obvious things i.e. fuse, loose board, etc. etc. Bottom line - it looks like the flyback transformer needs replacment This is what provides the picture tube with power/voltage, etc. The part itself is ~200.00 and the labor will be about $150.00 - $200.00. Thats what you would pay if its only the transformer. Usually when the transformer goes, it takes other components along with it. I am bringing my set to the recycling center since It's not worth fixing. Went to Costco and bought a 42" LCD tv for less than 900.00. Instead of spending upwards of $300.00-400.00 to fix a 13 yr old standard tv, go for the gusto and upgrade to High Defination TV with the appropriate Cable company box and you'll never regret it!!!!
What a wake up call to watch TV now!!!!!!!!! Good luck to you...
Sep 30, 2008 | Mitsubishi CS-35505 35" TV
1080i connection has green hue
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 09, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Cleaning lenses/lamps on mitsubishi VS-60805
A can of compressed air might do the trick. If dirt is stuch, I'd suggest useing the same chemicals/cloths/etc you would use for cleaning camera lenses. Check at your local photo store.
Just make sure the lenses aren't hot when you apply cold and/or flamable chemicals.
Nov 04, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Green color/tint over the display
yea you have to call a tech to make repairs to your tv it is having problem in the color circuit good luck
Apr 08, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
