Question about Sony KP-46WT510 46" Rear Projection HDTV
Sony kp-46wt500 problem with picture
I have a sony wide screen propjector tv, I purchased in 2003. the tv is now showing a shadow across the screen like a ghost or double lettering. what can do to fix
  • 2 more comments
  • Anonymous Mar 31, 2008
    topeft and bottom right conners of picture are bowed with the red and blue colors seperated.
  • cralws Apr 01, 2008
    unfocused picture with double image. All double image lettering in bright red. Auto focus and convergence adjustment does not remediate problem.
  • sixday44 Apr 06, 2008
    My 46 inch sony from 2003 is doing the same thing, the picture is bowed in the middle and all three colors are fairly out of focus. Has any found the cause of this yet?
    My kp-46wt510 sony widescreen from 2003 is doing the same thing, picture is bowed in the middle and the colors is completely out of focus.
    -Shayne
I'm having a problem keeping the timer from going off and shutting the whole tv off.
Posted on Mar 30, 2008
Image is showing in all three colors
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors.These parts must be change on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 07, 2010 | Sony KP-46WT500 46" Rear Projection...
Tried to use 2002 Sony TV as large monitor for webinar. Got the TV to accept signal but could never size the screen correctly. It only showed part of the computer image. Gave up on using it as large...
Symptom shows that it is convergence out chips failure that causing misaligned images on screen. Please replace convergence out chips in tv to get converge picture.
Question shows it is Sony KP-46WT500, if it is different model let me know please.
I can provide you more technical assistance if you wish to repair tv by yourself.
Thanks.
Feb 09, 2010 | Sony KP-46WT500 46" Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony kp 46wt500 has 3d screen what might the problem be?
If convergence out ICs got defective then TV shows that kind of picture.
Replace IC8001 and IC8002 on D Board, both big black ICs are mounted on aluminum heat sink and number STK392-560 would be written on it.
Required ICs are available in Part Store, click that link to see an image of IC and price info.
If you are not comfortable with soldering parts in circuit board, call local tv tech to replace it.
Thanks.
Nov 13, 2009 | Sony KP-46WT500 46" Rear Projection...
Shadow
The sony convergence Kit Type 1 available at the following link will usually repair that issue. The kit contains the parts plus a CD with detailed instructions to do the repair.
www.tvrepairkits.net
Jun 25, 2009 | Sony KP-46WT500 46" Rear Projection...
Ghost shadows on the Sony KP-46WT500TV
you can get the KP46WT510 convergence repair kit at the following link under convergence repair kits category which will also work for your model.
http://servicemanuals.vstore.ca/
Apr 12, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 Red, green and blue lines appearing on screen
your convergence IC;s are out, they cost about $40, if you know how to solder, you can do it your self, if not , I would try to find somone that can, service centers charge about 4 or 5 hundred, after you get the new ones, there easy to find on the board in the back of the tv
Nov 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Help
You need to have the convergence IC's replaced. A repair like this should run you about 300 bucks or so. In most places.
Apr 27, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony Wide Screen Projection TV 46"
Can you post a picture of what the screen looks like? It could be convergence amps or a pincushion problem. The pic would help clarify the diagnosis.
Feb 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
243 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
