Question about SmartDisk FireLite 40 GB Hard Drive
Dropped firelite: still spins but is not recognized
Dropped firelite: it spins but its blue lite does not light nor does the computer recognize it.
please help
tjm
  • ChuckieDev Jun 27, 2008
    Same problem,,, sometimes it lites, sometimes it doesnt. will not get recognized by any of the computers in my home...
    New Friend:
Ok same situation happened to me i dropped my Firelite 80Gig, drive would spin no light and the computer would not recognize the drive. All I did was open the case an saw the the internal hardrive had come loose from its pin connection. So all i did was pushed it back in and BAM now it works, hope this helps other people. Thanks C.J.
Posted on Jun 13, 2010
SOURCE:
Why does windows media player not recognize my firelite smart disc as a device. my computer recognizes it
Try rebooting your computer with the Smart Disk plugged in. You can also try moving all the contents of the Smart disk to your computer and access from there.
Aug 14, 2015 | SmartDisk FireLite 40 GB Hard Drive
My Macbook no longer recognizes my Firelite Hard Drive
It could be incorrectly formatted, if so you can reformat by using another computer that recognizes it or you may be able to find it on your laptop through a formatting tool. The formatting tool built into OSX is called "disk utility".
Oct 16, 2010 | SmartDisk FireLite 40 GB Hard Drive
Computer not recognizing
There's a fault inside. If you're lucky the fault is in the connector plate so removing the disk and putting it in a pc will allow you full access to the data. If when you do that the disk is still not recognized , or worse, it messes your pc, then the disk is dead and the data is lost.
Jul 12, 2010 | SmartDisk FireLite 60 GB Hard Drive
Firelite makes clicking sound and light on top pulses on and off
Sorry but your device has had it, with a bit of knowledge it may be posible to reove your files but you need to connect the hard dive out f its device housing directly to a computer.
Jul 04, 2010 | SmartDisk (USBFLB100) 100 GB Hard Drive
USB Device Not Recognized...
try to the laptop firewire port, if works. I didnt find any support for youfirelite drive
Dec 29, 2009 | SmartDisk FireLite 40 GB Hard Drive
My USB Port stopped recognizing my Smart Disk
on my computer right click and select properties, then go to the device manager. Under the USB device locate this device and delete and unplug the cable from the computer. Let the computer reboot, and plug the cable into another port if ava. and see what happens.
Oct 10, 2009 | Targus PA050U 4-Port USB Hub
Computer not recognizing external HD
1st try a different computers make sure its not your Hard drive!
2nd if that works then go to the hard drive maker and download a software driver for it that should fix the problem
Aug 10, 2009 | SmartDisk FireLite 40 GB Hard Drive
PowerBook G4 does not seem to recognize. (Worked well on previous Apple lap top)
If your Firelite SmartDisk was formatted for a PC, and you are using the Mac side of the G4 it won't. They use a different format scheme. Need to load Parallel, bootcamp, or another virtual PC program, and then Windows. Using that it will recognize it.
If you know another Mac user that is using both sides (Mac and Virtual PC) is a quick way to retrieve data to move it. Be careful reformatting the FireLite. There are some more complex ways. Hope that this helps.
AAirwolf
PS: I use a 160GB FireLite on my G4, MacBook Pro as well as my Tower and notebook PCs.
May 24, 2009 | FireLite (USBFLB80) Hard Drive
SmartDisk FireLite 40 GB Hard Drive Logo
420 people viewed this question
Top SmartDisk Computers & Internet Experts
Jeffrey Groves
Jeffrey Groves
Duncan Mutch
Kris
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
