Question about SmartDisk FireLite 40 GB Hard Drive
Dropped SmartDisk I accidentally dropped my external hard drive. The indicator light no longer comes on when the USB cable is plugged into the computer. Likewise th computer does not acknowledge the hard drive. The usual humming sound that is often generated by the hard drive has ceased. I took to Best Buy for repair but was told nothing could be done. I need help recovering my data. I accidently dropped my hard drive however it still spins but my computer does not recognize it nor doesit little blue light come on.... will i be able to recover my data?
    Master:
  • 788 Answers
Open up the external drive and remove the hard drive from inside.
Get a 2.5inch to 3.5inch ide hard drive adapter, you will then be able to plug the hard drive into a desktop computer and check if the disk is still readable. If it is and you still want an external you can get an empty 2.5" external hard drive enclosure for fairly cheap and but the drive into it. Otherwise if you data is unreadable then get a new external and start over.
Most tech shops worth their weight have a few of these adapters lying around and may agree to check the drive for you for free if you bring them the bare drive.
Posted on Mar 20, 2008
  • 4,234 Answers
Depending upon how hard the jar was to the internal mechanism, the data may be salvageable. I would guess that the first problem is broken connections at the USB connector. This case is just snapped together with a laptop drive in it. Carefully open it up and look for anything broken.
Worse case scenerio, you can get an adapter to plug the drive into a standard IDE cable inside your tower system.
Dan
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
May 08, 2010 | Toshiba 120GB USB 2.0 Portable External...
Dropped my1TB EXTERNAL Seagate drive, now not WORKING
Probably nothing. Hard drives are delicate machines seeing as th have microscopic lasers that are held by a tiny little arm between the discs. If it fell hard, so will all your DATA
Dec 19, 2009 | Computers & Internet
Blinking light in unusual pattern and ticking/clicking sound
TH eclikcing sounds like the heads are uffering from STICKTION give the drive a gentle but sharp jolt with the palm of your hane and see what happens
Aug 09, 2009 | SimpleTech (sti-u2f36/250) 250 GB Hard...
Dropped the 'My Book Essential' 500MB, now doesn't work
ok wow i dont even think i dropped mine but it doesnt work.. like the light flashes when i plug it in but then it isnt recognised...
Feb 03, 2009 | Western Digital My Book Essential 500GB...
Simpletech 250GB STORAGE S
try plugging your HD into another desktop/laptop to see if your HD is functioning well on a different computer. Could be the USB cable problem.
Feb 01, 2009 | SimpleTech SimpleDrive 160 GB External USB...
Laptop usb hard disk
I've had this problem many times with external SATA hard drive plugged into the usb. My 120gig hard drive takes significant power to operate it. On laptops with a long cable to the usb, I get the Tick tick tick sound and the light flash in concert with the ticking. On laptops with short cables to the usb, the hard drive works. On one desk top, the hard drive doesn't work on the front usb but does on the rear because the rear has no cables. The usb comes off the motherboard. Conclusion? Most likely a voltage problem from longer than usual cables from the motherboard to the usb. One solution is plug the hard drive in the rear usb. Another solution is buy a more expensive cable linking the hard drive to the usb. Or buy a shorter cable. More expensive cable may have thicker wires that won't resist the current. But I do not believe for a minute that the hard drive is faulty. I've seen it too many times and it has never been a faulty hard drive.
Sep 15, 2007 | Western Digital 320GB MyBook External USB...
Dropped SmartDisk
email me on warewolf2001@hotmail.com and i'll see what I can do
Nov 11, 2006 | SmartDisk FireLite 40 GB Hard Drive
SmartDisk FireLite 40 GB Hard Drive Logo
142 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
