Question about Maytag M3DH30B2A Dehumidifier
Empty tank, but "filled" light still on. Won't turn off
Ny Maytag dehumidifier was working fine. I emptied it, then plugged it in again and I get the light under "filled" and no action. In fact, it will not turn off unless I unplug it. Is there a reset button somewhere?
Many thanks, Joan
  • banksabj Mar 24, 2008
    We are having the same problem, ours is an LG. It says bucket full but bucket is empty.
    Genius:
  • 1,073 Answers
Be sure that you all have the bucket fully installed against the bucket switch, to see if the switch is bad, remove the bucket and press in on the switch, if the compressor starts then the bucket is out of place if it does not start then the bucket switch needs inspection
Posted on Apr 23, 2008
Fill light on and beeps but holding tank is empty
If it is like mine, the plastic part attached to the float in the collection bucket is broken and no longer actuates the switch that indicates the collection bucket (holding tank) is full. When I checked several years ago, the replacement part was no longer available. I used tape to keep the switch in the position that allowed the dehumidifier to operate and attached the hose connector to allow the condensate to drain. The collection bucket isn't needed anymore with this arrangement.
Oct 24, 2012 | Maytag M7DH65B2A Dehumidifier
My dehumidifier full light is on but the unit is empty and the fan motor won't work. Is there a way to reset it? Is that why the fan motor won't work?
This is generally causes by improperly installing the water collection bucket after removing it to empty it. Or the float valve in the top ow the water bucket s stuck in the "UP" position. Some Maytag models have a float control that moves from left to right, depending on how much water you want it to collect, before having to empty it. It may be stuck in the center position and needs to be moved left or right.
When installing the bucket, be sure that it fits into the holder "squarely" from top to bottom and makes contact with the bucket removal safety switch at the back of the bucket holder. When installed properly, the bucket should not tilt down at the bottom.
Hope this helps you and thanks for choosing FixYa.
Aug 06, 2011 | Maytag Dehumidifiers
Won't catch and empty water through attached hose.
My humidifier has a knockout inside the hose connection, that you have to remove. simple but check it out.
Jul 02, 2011 | Maytag Dehumidifiers
I plug in the dehumidifier, and all the operating lights go on, but it does not ever start working, no matter what I do with the settings. The water tank is empty, so it couldn't be that. Please help! ...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Mar 15, 2011 | Maytag M3DH30B2A Dehumidifier
Maytag Dehumidifier will not run. Indicator light says "full"
Here is a tip that I wrote to help people with just that dehumidifier2_bing.gif problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
May 02, 2010 | Maytag M7DH45B2A Dehumidifier
I plug in and it full light blinks..it is empty.
your tank is not sitting flat on the floor of your machine
Oct 12, 2009 | Maytag M7DH45B2A Dehumidifier
The bucket is empty, but when I plug it the full
I thnk your tank is askew. Adjust the osition of the tank until the light goes off ...
Oct 10, 2009 | Maytag M7DH65B2A Dehumidifier
Dehumidifer stopped collecting moisture, blows air w/ empty tank
Possible cause it's out of gas.
you might have to get a refridgeration mechanic to regas it, or/and fix any gas leaks
Apr 02, 2009 | Maytag M3DH30B2A Dehumidifier
Maytag electronic dehumidifiers full light stays on
Take out the bucket and locate the "full" switch in the upper right of the area where the bucket slides in. With the unit on, try pushing it in and see if the "full" light goes off.
If so, that switch is fine - if not try to adjust if and replace it if required. Those are generally micro-switches and firms like Radio Shack would have if your appliance parts dealer does not.
Aug 03, 2008 | Maytag M7DH45B2A Dehumidifier
Full light keeps blinking on Maytag dehumidifier
pull out the tank and see if you can find the switch that actuates that fault.... it may be the float swich for the bucket and it may be stuck... flip the float switch up and down a few times
Jul 20, 2008 | Maytag M7DH45B2A Dehumidifier
Maytag M3DH30B2A Dehumidifier Logo
180 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
