Question about Refrigerators
GE refrigerator issue
My GE fridge's top freezer only gets cold now in on corner of the freezer where the wires and tubes connect up to it. I thought it was due to something being frozen and causing a blockage, so I left it off for over a week in my shop with heat and the doors open. I even put pots of hot water in the freezer but it is still the same. I have look up the various parts for the fridge and I'm pretty handy, I just dont have knowledge of the refrigerator systems.. seems like a waste to toss, but it is at least 10 years old. I see used refrigerators on Craig's list for around $100 but that is always a gamble. is this worth fixing, should I try for another used one.. got this one used, or buy new... its a small frigerator in my workshop. I recently read about cleaning coils, something I have never done and the shop is dusty and the shop only has heat and ac when I use it... I'm in Raleigh NC. thanks for any help or advice you can provide.
    Problem Solver:
  • 4 Answers
Compressor is not running and pumping the freon effectively.
take and blow the coils clean with a air compressor or use a coil brush. If that doesn't take care of it you may have a compressor problem that is not worth repairing on a 10 yr old refrigerator.
Posted on Mar 20, 2008
    Problem Solver:
  • 6 Answers
Dirty coils could be on problem. Just take a vacuum ans **** all the dust and debris off the coils. Second, do you hear the fan running in the freezer compartment? Do you feel air coming out of the vents in the freezer compartment? If not that could be your problem also. If both of those things do not fix your problem, you may have a leak in your freon system. The easiest way to chech is look at your joints(usually happens by the compressor) and see if there are any "oil" spots. If this is the case, you are better off getting a new one.
SOURCE:
GE side by side GSS251FPA WW,Freezer not getting cold temp only 52
It's probably a faulty defrosting clock. I did see this type of problem caused by a faulty 'ground' connection at the wall outlet. Appliances often use the earth ground present in residential wiring systems as the neutral conductor for the internal appliance circuits.
So, if there are NOT all three prongs on the wall plug (people often cut them off), that could cause problems. But usually it's ice build-up inside the divider between the fridge and freezer, or the refrigeration coils are sometimes sealed in the top of the base.
You can look for bulging spots inside the unit. Or, unplug it and see if you get water on the floor.
The condenser, usually on the back of the unit (black tubing and wires, may be obstructed. If that can't get proper airflow, neither side of the unit will cool properly.
Jul 22, 2012 | GE Refrigerators
Hi our ge refrigerator has freezer on top its freezing but not keeping foods cold in fridge.fridge is warm and theres two holes in fridge on top that keep freezing up.what should we do?
by the number on the refrigerator its a side by side,if the freezer is actually on top,then remove rear cover inside the freezer and the drain hole in the freezers plugged with mold take a wire and rat out this hole to get water to flow down the hole again
Aug 07, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a GE GTS 222C top freezer refrigerator, approx. 8 years old. The freezer works fine but the frig doesn't cool and is at the highest setting. We had to turn the electricity off for some wiring...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | GE Refrigerators
Top of fridge/freezer will not cool
hi..the tubing that goes to the automatic defrost
gets clogged up and keeps the fridge from getting
cold.
check this out..
thank u..
rate me..
May 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Admiral SAC224 fridge freezer: fridge intermittently freezes up
To Whiteorchid,
Found a fix for my issue ... hopefully it'll help you.
Up at the topleft rearmost corner of the fridge remove panel to reveal spring attached slots where cold is supplied from freezer. The spring attached had came off one end as there isn't a "slot" for the spring to hold in place (design fault?).Reattached the spring and taped on .... and hey presto fridge now working perfectly again. Hope this helps.
Sep 01, 2008 | Admiral 26 cu. ft. Side-By-Side...
Creaking Sound when Opening Door of GE Profile PTS22LHSCC Refrigerator
My GE creaks too, and it started after we pulled it out for cleaning. It is normally the door hinges. Spray them with Jigaloo which is a dry silicone lubricant.
Try this. Go to your local tire repair place. Ask them for an old inner tube. Cut a double thickness square with scissors and put it under the 4 corners under where the wheels are. It should help them to become self leveling and also sound insulating..
Mar 23, 2017 | GE Profile PTS22LHSCC 33" 21.7 Cu. Ft....
GE Side By side doesn't cool and freexer frosts up
Most common problem on GE's is the defrost heater(s) has gone bad. They are a glass tube and when they go bad the tube will have a burnt or black color to it. A good heater will be clear. I bet that is your problem. Seems to be the problem about 90% of the time on GE not defrosting.
Jun 29, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
