Acer 2413lm Acer travalMate 2413LM,when bootinup, shows PXE-MOF Exiting PXE ROM OPerating System not found. Please Help
    Genius:
  • 1,601 Answers
It sounds like it cannot see the hard drive to boot from, or it is not trying to
boot from the hard drive.
You will have to go into your BIOS to check some things. Check the boot order.
Remove any reference to "LAN boot ", or at the very least, make it last on the list.
Make sure the hard drive is one of the choices. A good booting order is:
Optical drive (CD or DVD), Floppy, Hard Drive, and LAN would be last if you can't
remove it completely.
Now that you are in the BIOS, make sure that it recognizes the hard drive. Perhaps
BIOS can't see it because of bad connection, or bad cable, or some other reason,
such as hard drive itself going bad.
Check and clean the connections to the cables and hard drive.
Check to see if there are any upgrades for the BIOS available from the manufacturer.
Let us know if any of these ideas help.
Posted on Mar 20, 2008
6ya staff
SOURCE:
Hi, I'm trying to fix my friends Acer Aspire 5553.
try turning it on while pressing F8 to go to safe mode that might be one option
recovery disks are always a good thing to have on hand
May 22, 2012 | Acer Computers & Internet
Hi i just switch my laptop aspire 6920 on and its start beeping and then its show me Intel UNDI, PXE-2.1 (build 082) Copyright (C) 1997-2000 Intel Corporation For Atheros AR8121/AR8113 PCIE Ethernet...
enter to bios setup and remove Ethernet controller from boot sequence or make it last on the list. and about operating system not found if you already use your system without problem then reinstall the system from a cd .
Jul 23, 2011 | Acer Aspire 6920 Notebook PC
Went to shut down comp. and screen said, and still is. broadcom undi pxe-2.1 v11.4.1 copyright [c] 2000-2008 broadcom corporation copyright [c] 1997-2000 intel corporation all rights reserved. ...
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Dec 05, 2010 | Acer Aspire 5610-2328 Notebook
When I have turned on my Acer Aspire 6920 computer this morning it just goes to a screen that says the following Client MAC ADDR : 00 A0 D1 A8 32 D3 Check Cable COnnection PXE-MOF: Exiting Intel PXE ROM...
The first bit with the MAC address is there because it's trying to boot from LAN and it is exiting because no IP address is assigned to it by the DHCP. If your laptop is connected to a network, you can use this feature to image the laptop across the network with an imaging software like Norton Ghost.
The last bit, "Operating System Not found" means that you do not have Windows or any other operating system installed on your laptop. At this point, you can either reinstall your operating system or use the recovery disc that came with the laptop to restore it back to it's factory settings.
Dec 05, 2010 | Acer Aspire 6920-6621 Notebook
Broadcom UNDI PXE 2.1 v11 . 4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation All rights reserved. Broadcom Base Code PXE- 2.1 v1.1.0 Copyright (C)...
This is showing because the computer is not seeing the hard drive that contains the operating system. In some cases this is because the hard drive has come dislodged from the interface on the motherboard. Dells are good for this because the hard drive slides into the side of some models. Try reseating the hard drive and reboot. Your worse case scenario is that your hard drive has failed. The reason you are seeing the PXE-MOF etc. is that the laptop ias now looking for a network hard drive to boot from. It can't find the intenal hard drive so it is searching for other means to boot.
Jun 16, 2010 | Acer Aspire 3690-2196 Notebook
Pxe mof exiting pfe rom problems on acer laptop operating system not found.please assist cannot boot up
Go into the Bios and disable LAN boot.. usualy hit f2 or del as soon as it is booting up.
If this computer was working before.. then it cannot find the hard drive or anything to boot from and has gone to another place to try to boot.
Best wishes..
www.techvisitor.com
Sep 28, 2008 | Acer Aspire 5500 5570-2609 Laptop
ACER Aspire 3050: Operating System not found
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Since the computer is on, immediately start to press F2 or DEL button in order to enter the BIOS and reset all settings to default. Most likely you turned on the «Boot from network «option.
Sep 11, 2008 | Acer Aspire 3000 Notebook
Open Questions:
Computers & Internet Logo
79 people viewed this question
Ekse
Marvin
Marvin
