Question about Motorola Mobility PEBL U6 Cellular Phone
Pebble ringer inop
Pebble ringer, new out of the box, vibrates fine, but does not ring, even with ringer set on "7" loudness and on "Loud" ring preference. Have the same problem - although mine did ring for the first month I had it. Keypad tones are working, so it still has some quiet sounds.
Have tried master reset, but no change. Have tried different tones, volumes and profiles - still no success. Grateful for any advice.
    Master:
    Sergeant:
  • 462 Answers
There is an option in profiles stating as vibrate only or vibrate first then ring or both, so i request you to check that, it may help you else you can use your one year warranty to rectify it without spending.
Thankyou
Posted on Mar 20, 2008
    Master:
  • 788 Answers
Does it have a speakerphone function, does that work? It would seem that the second speaker is malfunctioning. There is usually seperate speakers for the earpeice and for the rigner/speakerphone. You could open the phone and make sure the speaker is sitting correctly, it could have rotated off it's contacts. But you may have to replace the speaker, possible found on eBay.
SOURCE:
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
LG EnV3 ringer volume is LOUD even when set to LOW
I have the same issue. I know this is a roundabout solution, but I love the phone in all other ways, so I handled it like this:
I make my own ringtones with audio editing software anyway, so I just made versions of my original ringtones that were "volume-cut" by 6dB or 12 dB. Then to get these .mp3 files installed as ringtones, first I save them to the "my_sounds" directory on the micro-SD card (either via USB cable and "USB Mass Storage" mode, or by taking the card out and plugging it into my PC with an SD card adapter,)
This puts them in as "sounds" but not yet ringtones. Then, on the phone itself, I send a multimedia message of each sound to myself (i.e. to this same phone, "from me to me") Once each message is received, you will get an option to "Save as Ringtone", and once you do that, the sounds become available as ringtones.
I just use ALL of my own "volume-cut" ringtones for the different ring sounds in my phone, and it makes it quieter. Note that if you then use any "standard" ringtones, they will seem particularly loud by comparison.
Oct 05, 2009 | LG enV3 VX9200 Cell Phone
How do I increase my ring tone volume on my Moto Razor .?
You can set the length of your incoming ring to in the Call forwarding portion of the phone. Usually, it is set to 25 seconds. It can go as high as 30 seconds. To set the ringer to be longer or shorter, it goes by 5,10,15,... set of 5 increments. up to 30.
I would also recommend to use a factory set ringtone, set the profile to LOUD or OUTDOORS. With vibrate option on. Some downloaded ringtones don't play as loud.
Feb 10, 2009 | Motorola Mobility RAZR V3
How do I get a louder ring on my blackberry 8700
From profile on desktop choose Loud and activate - The megaoohone logo at the top of the homepage should now have a red outline.
Jan 23, 2009 | RIM BlackBerry 8700g Smartphone
Cannot get Ringtones!
Go to settings, - Ring Styles, - select style - change it to loud, go to detail of loud and select ring volume and increase it to 7.
Jan 09, 2009 | Motorola Mobility RAZR V3
Pebble ringer inop
1 try this go setting initial/setup/master clear
password 000000 (6time) or full up 0 .
Mar 03, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Loud key sounds
with your v3 press <<>> select <<>> select <<>> in <<>> you must choose a ring style exemple:<<>> then goto <<>> and move to <<>> and change 7,6,5,4,3,2,1. Normaly, i put number 3 it's loud enought.
Aug 22, 2007 | Motorola Mobility RAZR V3
Will not ring or vibrate.
Go to settings... personalize....ring type... pick loud ...scroll down to edit then go in and change from silent to the ringer setting you choose
Jun 26, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Motorola Mobility PEBL U6 Cellular Phone Logo
145 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
