Question about HP Pavilion dv4000 Notebook
Wireless network system (wi-fi)
I have reboot my notebook due to some problem thru the operating system CD but wireless network system not installed and no icon found in the shortcut bar. Please advise.
  • 520 Answers
It may be disabled and if so will not show.goto control panel and check network devices and check.
also check device manager to see if device installed.
If no software is installed go to hp site and download it.
Posted on Mar 29, 2008
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Wlan card disabled
The Dell Latitude E6400 laptop comes with an Intel Core 2 Duo processor for fast computing and an NVIDIA graphics card for video playback, gaming and Web browsing. The laptop has a built in Wi-Fi card, letting you connect to the Internet on-the-go. However, if you're unfamiliar with Dell or the laptop's factory installed Windows Vista operating system, you might not know how to enable to Wi-Fi.
Slide the switch on the side of the laptop toward the front of the laptop. This switch enables Wi-Fi connectivity on the Dell Latitude E6400. When switched into the back position, the Wi-Fi is turned off. Turn on your Dell Latitude E6400 laptop and log into Windows Vista. Click on the Windows "Start" button. Click on "Wireless," located in the Start menu's "Show" list. A list of currently broadcasting wireless networks appears on screen. With your Wi-Fi enabled, you can connect to any of these available networks. Secured networks ask you for a password when you click "Connect," while unsecured networks connect automatically.
Feb 03, 2013 | Dell Latitude E6400 Notebook
Cannot turn on wireless lan with fn+f2 keys
1. first turn on the "wi-fi/wireless" switch on ur laptop manually.
2. now use the key combination for wi-fi/wireless
3. if it still not working, reinstall the wi-fi/wireless driver again, and restart ur system
Jan 01, 2010 | ASUS F6A-X2 PC Notebook
Black screen after turn on
That "Blue Screen" is also known as "Blue screen of Death".
The problem is due driver compatibilty or unstablity.
Try to boot your system to "Safe Boot" by pressing F8 during startup.
Select "Last know good Configuration that works"
Check if it can take you to desktop.
Unstalled the wi-fi driver and reboot.
If the above procedure fails, again
Select "Safe boot"
Now create a restore point  and download the lastest version of your WI-Fi driver and installed.
This should work fine.
Otherwise Backup all your important data from your hard drive (mainly opearting system file installed drive usually C:\) and go for a new Installation.
Dec 28, 2009 | Acer Aspire One PC Notebook
Problem with on or two network adapter
First make sure that wi fi switch of your laptop is turn on.
Then check that wi fi netowkr adapter driver is installed perfect and enable.
Go to device manager and enable wi fi adapter.
For check device manager right click on my computer icon then click on property then hardware ->device manager.
Then you see all driver list.
Then enable wi fi .
Also right click on my computer places icon then go to proeprty then you can see your network adapter right click on wi fi adapter then click on "view available wi fi networks."
then connect your wi fi .
Let me know if you need more assistance.Thanks.
Oct 01, 2009 | Acer Aspire 4720 Notebook
IBM ThinkPad T40 no LAN or internet connection
Fot that first you need wi fi router with intenret connection .
Then check in your laptop that your wi fi network adapter driver are installed.
Also check its wi fi switch is turn on it is on laptop.
Check your wireless in router is enabled.
also check your wi fi network adapter is enabled in your LAPTOP.
Let me know if you want to configure your router and if you need more assistanse .
thanks.
Aug 26, 2009 | IBM ThinkPad T40 2373 Notebook
How do i set up this comp. to show wireless connections
Install wi fi network adapter driver.
Turn on wi fi switch it is on laptop you can find it easily.
Then you can see your wi fi network in my network places.
Jul 31, 2009 | Dell Inspiron 2200 Notebook
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Unable to connect to wi-fi
I think it is saying that the wifi "card" is set so that it is not being configured by windows.
In XP
Control panel > Network connections
Under LAN or High-speed internet you will see an icon labelled wireless network connection. Right click on this and then click properties. You will see three tabs at the top
General - Wireless Networks - Advanced
Click on wireless networks
There should be a tick-box saying Use windows to configure my wireless network settings. I expect that, in your case, the box is unticked which means that the software supplied by the vendor of the wifi card is configuring the settings. I find that it is usually more reliable to let windows do it.
So tick the box and click OK. You may then have to reboot.
Dec 26, 2008 | Toshiba Satellite M45-S265 Notebook
HP Pavilion dv4000 Notebook Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
