Need to replacement processor fan.Brand name GIGABYTE with p/n 401012...Need to know who to get it from...And where?
    Problem Solver:
  • 17 Answers
What I would do is just bring the fan into one of your little local computer shops. Fans do not need to be replaced with original parts. In almost every case you will end up with a better fan then the original which would keep your cpu cooler causing better performance and longer life.
Bring the old fan to them so that they can see the mount style and make sure they give you one that will fit onto your board.
I have seen fans run as cheap as $10 and go way up there. typically you can get a better replacement fan for about $20
Posted on Mar 20, 2008
CPU fan & PSU fan working but No display coming to the screen
There should be some sort of beeps then. No beeps is an indication the CPU or RAM is not seated properly. You need to refer to board manual if there are beeps.
There is also the matter of... Never mind I just noticed the CPU is an 8 core CPU, but the board supports quad core.
Board specs
http://www.gigabyte.com/products/product-page.aspx?pid=3833#sp
CPU Specs
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103960
Double check my findings and go from there. Good Luck
Dec 11, 2012 | Gigabyte Technology gigabyte Ga-78lmt-USB3...
Hi, in my computer properties,it shows only the processor's name amd sympron 2400.. i culdnt find the motherboard name,as its not shown in that, cud u please help me to find motherboard name,as i need...
This is Gigabyte Support > 7VM400M-RZ motherboard > Main support page,
http://tw2005.giga-byte.com/Motherboard/Products/Products_Spec_7VM400M-RZ.htm
In the small chart in the middle where it states, Overview, Awards, BIOS, Comparison Sheet, CPU Support List Driver, FAQ, Manual, and News, click on > Driver.
(AMD Sempron 2400+
That fits in a Socket A processor socket. Socket A is also known as Socket 462.
Click on Manual for the motherboard manual)
Nov 24, 2010 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
HI ! I bought a new AMD phenom quad-core 9750 2.40ghz processor and Gigabyte motherboard. I m unable to install Windows and the system automatically shuts down every 20 min and sometimes runs for more...
This processor need better cooling system as it is powerful it need more power so I suggest you to upgrade your Power Supply and buy more efficient processor fan cooler. Also you should check if processor is properly installed on motherboard and there should be some special thermal grease between processor and motherboard (http://en.wikipedia.org/wiki/Thermal_grease) for better thermal conductivity
Oct 25, 2010 | AMD Phenom X4 9750 Quad Core Processor...
WHAT CPU HEATSINK & FAN ASSEMBLY WOULD I NEED FOR THIS A GIGABYTE MOTHERBOARD (MODEL # GA-945GZM-S2)? PLEASE! NEED TO KNOW MM SIZE TO GET AND ??? WHAT ELSE?? THANKS Kathy from Florida :-)
Something like this one
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4950633&CatId=1588
powerful enough to handle all processors that your board accepts.
Jul 08, 2010 | Gigabyte GA-945GZM-S2 Motherboard
Gigabyte motherboard problem
I suggest you replace the motherboard.
If you know a service center near you that can fix motherboard then bring it to them to have it check.
May 20, 2010 | Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G...
How to check the warranty of gigabyte motherboard
hi there, warranty is always indicated on your receipt of purchase.you can check the date of effective due date. also be sure the specification no.this include the model,brand name, serial no, of *********** board complied to the receipt of purchase.have a nice day,the gigabyte of mother board was located on the processor unit.have a nice day.thanks alot
May 10, 2010 | Computers & Internet
P4 2.66GHz 533FSB Problem on Gigabyte GA-8ID533
well if the board support till 400FSb then the 533FSb CPU will not work with the board did you check the website and he board manual that says it support upto 533 bus?
Nov 08, 2008 | Gigabyte GA-8ID533 Motherboard
Replaced Mobo & Processor Nothing Working
May I know the model of your gigabyte mobo, you just replaced your unit with.
'cause it may not be compatible with the new power suply you have upgraded with.
Thanks
Sep 26, 2008 | Computers & Internet
Troubleshooting
What is the brand name of the ram you are using? If you look up on AMD's website, it will tell you what RAM is compatable with your processor and mobo. 45 degrees celcius translates to 113 farenheit. If it is a constant temp that way, it is ok. But just at IDLE speed, means the processor is getting over heated more than likely after opening multiple apps.
Mar 17, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
