This is gunk build up under the agitator and/or the drain area under the drum. It needs to come apart...
I also have a Maytag Neptune! I had this problem until I found out about these cleaning "pucks" they have. You put one into the drum, run a cycle on the washing machine and then after it's done, you use a "grit grabber" cloth to clean the rubber seal around the door!!!! It works awesome!!!!! You can get it at your local Maytag store or go online. I have recently found the pucks at Walmart! I do this about every 3 months! My washer stays fresh and clean!
