The buzzing sound can be from arcing at the lamp connectors, please verify that all the lamp connectors are seated back into the socket securely. Try checking that first and post back. I have done that sometime myself. Hopefully it is not from lamp assemblies.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Testimonial: "Very helpfull. Thanks for your expertise on these monitors."
Tough call from this far away...
What type of capacitors did you use? You MUST use 105 degree high frequency capacitors.
Each of those capacitors is a power output to the board. Can you measure any of the leads? (should be a 5volt, a 3.3 volt and maybe a 12 or 15 volt) One voltage will fall when the squeal starts - that's the problem area.
I suspect there is a problem on the high voltage board for driving the backlight. There are electrolytics on it, too. That will cause a squeal for sure...
Testimonial: "Thanks for your expertise and suggestions. I am still solving the problem as I found another liking cap that I'll change. Thanks"
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Thanks for your help. Looking at waht you suggested, I found another liking cap, the big one by the transformer, I'll change it and also check the conector as you suggested and let youy know. thanks again
Hi. thanks for your tips. Looking at the grade of the caps I found another liking cap, the big one bvy the transformer, I'll change it and let you know.
Thanks
