Question about Samsung SyncMaster 1100MB 21" CRT Monitor
Samsung Syncmaster 1100MB
Wen PC starts i become next popup:
Debug Assertion Failed!
Program:..Files\Hardware\Samsung\SEC\Natural Color\NaturalColorLoad.exe
File: C:\Work\nc2_20020220\-for symbols- \NaturalColorLoad\SystemTray.cpp
Line: 124
For information on how your program can cause an assertion
failure, see the Visual C++ documentation on asserts
(Press Retry to debug the application)
..and wen I press Retry is likes to go good.
How can I make this problem to an end.
Thank you
Connect monitor with PnP (D-sub) instead of BNC and install Natural Color again
Posted on Mar 22, 2008
    Genius:
  • 1,913 Answers
Hi install your monitor utility and drivers
run the CHKDSK utility
Posted on Mar 20, 2008
SOURCE:
Debug error
An "assertion" is a booby-trap inside a computer program.
Under normal conditions, the programmer has determined that his/her program will always find that the \'ASSERT\' statement is "true", e.g., \'ASSERT X > 0\'. However, in your case, somehow the value of \'X\' makes the statement to be "false". Then, the program "stops", due to something seriously being "wrong".
It\'s either some incorrect input data being fed to the program, or a "software-bug" inside the program.
Check your input.
Contact the author of the program.
Mar 13, 2014 | Microsoft XP Computers & Internet
There is a bright spot on the middle of screen, of my model no 1100mb. model code ks21cnibhk/xtp
The picture tube is at fault.Since its at the center it indicates that the phospors at the center are burnt/faded & not able to reproduce the colors it was meant to. My advice would be to buy a new monitor since changing the picture tube is not cost effective
Dec 09, 2010 | Samsung SyncMaster 1100MB 21" CRT Monitor
I have just connected my old (beloved) SyncMaster 1100MB to my new computer with Windows 7. I can only get a refresh rate of max 60 Hz to the monitor. It gives too much flicker. How can I get a higher...
Right click your desktop and select "properties". On the last tab (where you set the resolution) click the "advanced" button. On the new property sheet go to the monitor tab and uncheck the box that say something like "hide modes that this monitor does not support". Click OK then. Now you should have everything up to 200 Hz.
Hope this helps. If you need any more assistance, don't hesitate to come back to me. Else, if the problem is solved, please do ACCEPT this solution. Best Wishes. Thanks for using FixYa.
Nov 05, 2010 | Samsung SyncMaster 1100MB 21" CRT Monitor
When i start an account program there is message popup "maximmum resolution.....like that" how to remove it
Inspect/change the display settings on your system - LCD displays "like" certain settings and actually offer this advice when they "see" a mismatch. For modern Windows, right click empy area of desktop and choose Display Settings
Feb 28, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
I need driver
No, you don't need a driver. This is a "plug-and-play" device.
Your Operating System (Windows XP??) will adapt to the capabilities of the device.
Jan 07, 2010 | Samsung SyncMaster 1100MB 21" CRT Monitor
Error str: null!
what operating system? If it is a newer operating system or vista it may not run an older game at all.
Nov 02, 2009 | Computers & Internet
Getting an error message when starting the PSR 2100
I would do a factory reset. Search Google for: factory reset PSR 2100.
It will be holding certain buttons or keys down when powering on.
Sep 18, 2009 | Yamaha Music
Debug assertion failed
okay open internet explorer and then click tools>internet options. then go to the advanced tab and make sure debugging is turned off
Apr 27, 2008 | Compaq Presario 5000 PC Desktop
Samsung, SyncMaster 1100MB
Hi idil that is very simple
in only 4 conditions the monitors shakes like that they are
1. Give 1 feet gap between speakers and the monitor
2. Give 1 feet gap between Ups and the monitor
3. Give 6 feet gap between all the radiation things
4. Check the power voltage up and downs
Thank you
Apr 16, 2008 | Samsung SyncMaster 1100MB 21" CRT Monitor
Open Questions:
-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}
Oct 16, 2019 | Computers & Internet
-\&;-OPTONLINE Customer Care Phone Number #{+ I8OO-828-O294 } AB .U.S.A This Optonline USA phone number is ranked #2 out of 2 because 7,728 Optonline USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Optonline USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Optonline USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Optonline USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Optonline USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Optonline USA Calling Optonline USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Optonline USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Optonline USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Optonline USA's phone numbers against each other. Contacting Optonline USA in General While I8OO8280294 is Optonline USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Optonline USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Optonline USA.
Oct 16, 2019 | Best Computers & Internet
Hackers apparently from India have taken over FIXYA and 6YA. Don't trust your password, credit card information, or personal information here. This Comcast USA phone number is ranked #2 out of 2 because 7,728 Comcast USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Comcast USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Comcast USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Comcast USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Comcast USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Comcast USA Calling Comcast USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Comcast USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Comcast USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Comcast USA's phone numbers against each other. Contacting Comcast USA in General While I8OO8280294 is Comcast USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Comcast USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Comcast USA.
See all Samsung SyncMaster 1100MB 21" CRT Monitor Questions
Samsung SyncMaster 1100MB 21" CRT Monitor Logo
256 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
