Question about Dell Latitude CPI Notebook
DELL Latitude CPi A Series
I got a DELL Latitude CPi A Series off ebay as unknown if works or not. I got the AC Adapter in today for it and awaiting the HDD Caddy. The laptop power lights come on but no fan and no display come on. After about 2sec. the power light switches over to the battery light. I think that it is shutting off. I don't think its the RAM. Because if it didn't have a hard drive or memory it still would power on showing the DELL logo on screen and then go to a black screen saying No operating system found. Other than that this looks brand new, no scratches or anything. Thanks...
  • 3 more comments
  • Patrick Bridge
    Patrick Bridge Mar 20, 2008
    I read information on google and it said to take a out a chip called EEPROM chip. I did this and the machine wouldn't power on at all. I put it back in and did the same as before. Can this be the problem? Thanks...
  • Patrick Bridge
    The Chip is located next to where the memory is...
  • Patrick Bridge
    Patrick Bridge Mar 21, 2008
    I've tryed all of these and all it does is turns on for 7sec. with the green light on the top and then goes off. And the fan nor the screen come on. I took the entire thing apart to see if anything was not connected or broke and everything checks out ok. And then put back together. What does the EEPROM chip do. I took it out to see if that was it and it didn't turn on at all. So I put it back in and still turns on for the 7sec. Its next where the Memory is.
  • Patrick Bridge
    And I also don't even see a CMOS battery in this machine anywhere...
  • Patrick Bridge
    Patrick Bridge Mar 22, 2008
    Do you think its because it don't have the Hard Drive caddy? I'm awaiting for the Hard drive caddy to come in So I can put in the hard drive. I have to have the caddy because the hard drive will not connect to the laptop with the adapter built on the caddy.
    Problem Solver:
  • 17 Answers
Something to try would be to re-seat the ram and harddrive.
just take them out and then put them back in and try again. I would try with the battery out and just the ac power plugged in.
Being that it was bought off eBay, realistically it probably got banged around a little bit. Sometimes if one of the devices are not making a real good contact it can cause these problems. I have also seen bad batteries cause this problem.
This is not necessarily going to fix your problem, but it has occasionally worked for me in the past and it is a very quick and free thing to try.
Posted on Mar 20, 2008
  • Anonymous Mar 21, 2008
    it is starting to sound like the motherboard to me. sorry for the bad news.
SOURCE:
How do i replace ide/eide cable on my dell latitude c840
Buy a replacement and fit it I guess. Why would you need to replace an item that doesn't fail?
As far as I am aware there is an adapter; http://www.ebay.co.uk/itm/HDD-Hard-Disk-Drive-Caddy-IDE-Adapter-Connector-DELL-LATITUDE-C800-C810-C840-/380698290269?pt=Laptop_Adapters_Chargers&hash=item58a362e85d and maybe a flexible cable; but that is for the screen.
Jan 21, 2014 | Dell Latitude C840 Notebook
Dell latitude e6410 chargin fault ,will run on dc adapter but shows not chargin ,battery not conected
  1. If the motherboard has ever been replaced, check the service tag section of the BIOS. If it is blank, enter the service tag off the bottom of the system. (The charging circuit will not work without it.)
  2. Also in the BIOS see if the AC adapter is identified or is listed as UNKNOWN. If the system cannot ID the adapter as a Dell Branded AC adapter 90w or larger, then the charger is again disabled. If unknown, check the barrel end of the DC jack of the adapter for the fine wire in the center, if broken or bent, then the adapter is not identified.
  3. Try with a different Dell branded 90w or larger D or E series adapter.
if all the above make no difference, and the Adapter is recognized, the battery may be at fault.
http://www.fixya.com/support/r3743571-long_will_battery_in_portable_computer
if the adapter is unknown, replace the adapter, unless it works normally on another system, and the other system's adapter has the same issue, in that case the motherboard is likely the issue.
Note: a 65w Auto/Air adapter will only charge the battery if the system is OFF
Jul 27, 2011 | Dell Latitude E6410 Notebook
I hate neighbors! I had given my laptop to the boy livin next door and he returned it with the shift key missing. I will have to buy a new keyboard now 
Hi james,
sorry to hear that your kindness to another has been let down .
to replace the keys or the whole keyboard is not too big a job .
try searching on ebay for a replace keyboard ( in the uk around 20 pounds ) or buy a used one and change the key top
this is a link below to ebay as an example
http://cgi.ebay.co.uk/Dell-Latitude-CP-CPi-Series-Laptop-Keyboard-0000309R-/380158661597?cmd=ViewItem&pt=UK_Computing_ComputerComponents_KeyboardsMice&hash=item588338d3dd
Jul 19, 2010 | Dell Latitude CPi A Laptop Keyboard Unit (...
Hi i am using dell latitude d600 problem with charging the battery 3 or 4 time orange light flash n 1 time green light . im unable to use my laptop with battery it working well with A.C power
Try to perform power drain. Take out the battery unplug the power adapter then press and hold the power button for 30secs. Put the battery back in then plugin in the power adapter then turn on the computer. If same issue occur, then you need to replace your battery.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
May 18, 2010 | Dell Latitude D600 Notebook
MY BATTERY NOT CHARGING... UNKNOWN AC ADAPTER SHOWING
1st try a different AC adapter. If no change, flash the BIOS, If still no change, Replace the Battery, if issue still occurs,replace the MB
Aug 15, 2009 | Dell Latitude D610 Notebook
I have a dell laptop latitude d600 and it will not turn on. the power supply light is on and when u plug it into the computer it turns off and the computer will not turn on and the power supply light goes...
There are 2 possible points of failure here. The AC adapter or the Motherboard. If possible, try a different D-Series AC adapter from a known good system and see if there is any change. Also test your adapter on a known good Dell if possible. If the adapter is the fault, then replace it. If a known good adapter has the same issue, then the motherboard is at fault and needs replacement. Motherboard are about $100 on EBay
Jun 04, 2009 | Dell Latitude D600 Notebook
Where do i find the battery compartment
try this http://tinyurl.com/cmwr8j it is on ebay
Jan 25, 2009 | Dell Latitude CPI Notebook
Hard Drive is not showing
Just chk all the connections to the drive and make sure they r fixed and tight.
Incase it still exists try ur HDD with some other system.
and if it still does not work then probably ur HDD has crashed(BADLUCK!)
Jul 08, 2008 | Dell Latitude CPI Notebook
Dosplay
Probably have to go to dell and download video drivers for your latitude
Jun 07, 2008 | Dell 20GB NOTEBOOK HARD DRIVE KIT FOR...
Latitude CPI A-Series
log on to www.dell.com and place an online order for a new DELL system
Apr 24, 2008 | Dell Latitude CPI Notebook
Dell Latitude CPI Notebook Logo
166 people viewed this question
Ekse
Clive
Clive
