Question about Philips 42PF7320A 42 in. Plasma HDTV
Top half of screen goes black
I know someone else posted this, but I'm still searching for a real solution, or at least some idea of what exactly is causing the problem, if it is DIY fixable, or how much it might cost to get fixed.
After about an hour of use, the top half of the display goes black. Sound and the bottom half of the display are fine. Doesn't matter what cables or AV source I'm using (DVD, Cable box, Wii, etc). I've tried component cables and HDMI).
I've heard it happens with some Samsung plasmas too (they used some of the same inner parts as the Philips).
  • marcoman Mar 24, 2008
    My screen sometimes goes black from the halfway point to the bottom of the screen. It may fluctuate from a normal picture to the half screen intermittently. Sometimes the black half will turn to a white background with vertical multi colored lines. The top vent on the tv also seems really hot with the left viewer side a slight bit hotter feeling than the viewer right side.
    Scholar:
  • 72 Answers
Sounds like your having problems with your Y-main(upper buffer) is getting too hot. The IC's located on this board are really bad about going out a lot. If you take the back cover off your Plasma. U will see that the manufacture of the panel is Samsung and the panel model is probably S42AX-YB01. you should be able to purchase the board. probably will run about $ 150.00.
Hope this helps
Posted on Apr 08, 2008
SAMSUNG 51 INCH PLASMA , BOY THREW HIS BEAN CUSHION AT IT AND NOW EXACTLY HALF THE SCREEN HAS VERTICAL LINES OTHER HALF PICTURE IS FINE .ANY IDEAS WOULD BE APPRECIATED .
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
May 01, 2017 | Samsung Televison & Video
Samsung UN55HU7200FXZA. Black screen. When turn on,Verticals white & black lines, and after 2 seconds goes black (no video).
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 20, 2017 | Samsung UN55HU7250 Curved 55 Inch Ultra
LG plasma TV. Top half of screen is black. Trying to find out which board needs replaced.
Jan 12, 2017 | LG Televison & Video
When I turn on my Sony kdl60nx800 then screen vertical split, half black and half white. No image appears. How can I fix that?
Sounds like T'Con board fault. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jan 09, 2017 | Cars & Trucks
New curved Samsung has broken black lines at top of screen and half of one quarter way down. Is it terrestrial aerial or model fault?
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Dec 06, 2016 | Samsung Televison & Video
My LED TV has the picture in two equal vertical sections with the right one having lower black level and that is for all inputs and even with no input , the black screen is half black and half gray
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Nov 21, 2016 | LG Televison & Video
How To fix my TV screen? half bottom black & half OK
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 20, 2015 | Televison & Video
Screen comes on for less than a second and goes black
If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine and half Lakh viewers cannot be wrong.
May 11, 2013 | Televison & Video
Top half of my 50" LG Plasma (50pk540) is black.
Y-Sustan board should be suspected. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2300 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Fault to Plasma displays are described in detail with screen shots.
Apr 15, 2013 | Televison & Video
I have a Mitsubishi PD 5010 plasma tv. I turned it on and it now has these black rectangular boxes on its screen one in the upper right hand side that goes down almost about half way and another in the...
Post a screenshot. If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 19, 2017 | Mitsubishi PD-5010 50 in. Plasma...
Philips 42PF7320A 42 in. Plasma HDTV Logo
240 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
