Question about Sony PlayStation Portable (PSP) Console
Psp how do i put AOSS on my 3.90 firmware psp
  • 31 Answers
You have to go onto NETWORK SETTINGS
then go into inffastructive mode
NEW CONNECTION
then you have to go into Automatic
And there you will find the AOSS
hope to of been of help
Mike @ psp-repairs08
Posted on Mar 26, 2008
SOURCE:
Where is the aoss button at on psp
HI. This question and issue is one of the most misunderstood attributes of the PSP unit. Essentially; The AOSS Button and indicator are on your router. This is not on the PSP hand held device, at all. With that said; There were some earlier models that actually had this particular button on the top right side of the device. This has been removed and is not part of the newer PSP designs.
In order to connect an AOSS-enabled client(PSP) to a compatible router, you first will need to press the router's AOSS button for 3-5 seconds; which illuminates a flashing amber indicator on the unit. This puts the router into "AOSS mode," during which it can accept configuration requests from AOSS clients. Make sure you align your PSP Parallel with the router to get Max signal strength.
NOTE_ There are some routers on the market(low level), that are not equipped with this feature.linksys models will be one of those none AOSS compatible brands, among others.
Nov 30, 2010 | Video Game Consoles & Games
AOSS is what you would see on some high end routers. if your router doesn't support this method or have this button you can't set up your psp using it.
The psp does not have an AOSS button. AOSS (AirStation OneTouch Secure System) is used for wireless setup of devices like your psp for your network. Your router will have a button on it for this. If it does not then it more than likely does not have the ability to set up the devices in this manner.
here is the steps for setting it up if you did have this feature on your router.
1)To use this set up for the PSP go to Settings>Network Settings> infrastructure mode>new connection>automatic - AOSS. At this point the PSP will tell you to push the button on the router and that you have two minutes or else the attempt to connect will stop.
again this only works if your router has the AOSS button. and it is not found on your psp.
May 12, 2010 | Sony PlayStation Portable (PSP) Console
Where is the aoss button on the psp console?
the aoss button is not on the psp it is on another device on that device you press the aoss button to connect the psp to it
Jan 12, 2010 | Sony PlayStation Portable (PSP) Console
Were is the aoss button on the psp
You should find the aoss button near the power on/off button. Older PSP models dont have aoss button in which case you need to set it up with the router.
Jul 10, 2009 | Sony PlayStation Portable (PSP) Console
I cant find the aoss button on my 1000 verson psp
Near the right side of you psp if it is new there should be a small button near the power button that is the aoss button.
Jun 19, 2009 | Sony PlayStation Portable (PSP) Console
WHERE IS THE AOSS BUTTON O A PSP
The psp doesnt have an aoss button- this is located on your reuter but very few reuters have this feature.
May 27, 2009 | Sony PSP (Piano Black)
Weres the aoss button
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I think there is no AOSS button on your PSP. AOSS is a wireless solution made by www.buffalotech.com. Most new wireless routers/access points has this capability. AOSS is on the wireless router/access point and not on the PSP.
AOSS will automagically determines and configures the connection of a PSP to a wireless access point by pressing the AOSS button on the wireless access point.
Apr 09, 2009 | Sony PlayStation Portable (PSP) Slim...
Slim slick psp probloms
Sir, i think what the PSP is refering to is on the actual router, not the PSP itself...Have you tried checking your router if it has that "AOSS" button on top of it?
Jul 24, 2008 | Sony PlayStation Portable (PSP) Console
Where is the aoss button on psp
The aoss button is not on your psp Its on your stick, hold down the left on your stick. <> It will start blinking. if you dont know what i mean still.There are to lil simbles on your left of the psp They are very small. up just a little bit is a stick.sometime you use the stick to operate your game.(move) Click the left of it. If you dont get that then your ******* stupid
Mar 18, 2008 | Sony PlayStation Portable (PSP) Console
Downloading games from my psp site
the problem is that the slims are unable to play downloaded games without being reverted to an older firmware and than putting a custom firmware on it. unfortunately the only way to do this on a slim psp is with a pandora battery. they can be purchased but can be pretty expensive. the alternative to purchasing a pandora battery is to make one yourself. if you decide to make one yourself the files are readily available from mos torrent sites and tutorials on how to do so can be found on www.pspscene.net. if you have any further questions i would ask that you direct them to the knowledgeable people who occupy the forums there. hope this helped.
Feb 28, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
