Laptop problem the laptop starts but it dose not go to the start up page it says media test failure
    Genius:
  • 1,601 Answers
I'll give you the bad news. Sounds like your hard drive has failed. laptop problem - sad.gif
Posted on Mar 20, 2008
Pxe-61 media test failure.check cable pxe-mof: existing pxe rom.loading drmk v8.00
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard drive.
Verify your boot options are properly set in CMOS setup. We recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
If your CMOS Setup has an option to boot from the LAN disable this option.
If you have changed any CMOS settings, make sure to save and reboot the computer.
If this does not resolve the issue, try resetting the CMOS values to the default settings, save and exit.
Then try re-booting and tapping the f12 key which should start up a diagnostics page
Mar 06, 2014 | Dell Vostro 3700 Laptop Computer PC...
6 beeps what dose it means
Dell beep codes:
If your computer beeps during start-up:
Run Dell Diagnostics to identify a more serious cause.
Beep Codes Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3-1) consists of one beep, a burst of three beeps, and then one beep. This beep code tells you that the computer encountered a memory problem.
Contact Dell for technical assistance.
Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM read/write failure 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer failure 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3 Video Memory test failure 1-3-1 through 2-4-4 Memory not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller test failure 3-3-1 NVRAM power loss 3-3-2 Invalid NVRAM configuration 3-3-4 Video Memory test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No timer tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math-coprocessor test failure 4-4-4 Cache test failure
Aug 12, 2013 | Dell Gx620 Gx 620 Sff P4 Ht 2.8ghz 1gb...
Toshiba satellite pro l450-13q PXE-E61 media test failure check cable
This indicates hard drive issues, or windows files have been corrupted. If you have a backup disk try and load windows, no change! have the hard drive tested for possible replacement.
Jul 08, 2012 | Toshiba Satellite Computers & Internet
My toshiba satellite laptop L455-S5046 keeps saying when i start the computer media test failure, check cable and i dont have the recovery discs to reformat it. what do i do next? is there a place to...
The media test failure could indicate a failed hard drive. You can order one for cheap on newegg.com or pick one up at bestbuy for under $50 You would need a 2.5" sata hard drive. Comment if you need help installing it.
You will want to contact toshiba and order the recovery media. There is no way to just download it unfortunately.
Toshiba Support for the United States Computers: (800) 457-7777 (toll-free) or (949) 859-4273
Toshiba contact page http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/navShell.jsp?cf=su_contact&pf=true
Tell them you need to order "recovery discs" and they will probably ask for the serial number. I've seen the recovery media run from $16-80 depending on manufacturer.
Comment if you need additional assistance.
Aug 06, 2011 | Computers & Internet
Media test faiture, check cable error message ,
The error is related to your network interface card. In a lot of laptops this is integrated to the motherboard and can't be switched out at home. You will need to take the laptop in for service to have the card replaced.
Sep 27, 2009 | Sony VAIO Notebook
I was hopeing somebody could help, this morning i went onto the laptop and then restarted the laptop, when i restarted the laptop the laptop kept on rebooting its self. i first comes up with compaq logo,...
Try to start in safe mode, then change the start up options so that the computer does not reboot on error. Then you can see what the BSOD (stop error) message is and troubleshoot from there.
May 05, 2009 | Compaq Armada E500 Notebook
Computer continually rebooting problem
You could try a windows repair install.
Apr 19, 2009 | Compaq Armada E500 Notebook
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
PXE-E61: media test failure, check cable.
Save your self a lot of reading, do this first.
Check in BIOS rom for start up sequence and check if there is an asterist (!) in front of the hdd. If there is, it’s disabled. Select the hdd and press shift key plus “1′ This removes the ! and you can then use the hdd to re-format or….
Dec 15, 2007 | Toshiba Satellite A105-S4004 Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
