Question about JVC KD-G720 CD Player
How do I get sattelite radio on my jvc? How does it connect?
Hello. I am trying to get an understanding of how to get sattelite on this stereo.
  • 27 Answers
I'm not familier with this specific player, but my guess is that it doesn't have a built in satellite radio receiver. It probably controls and displays an add-on satellite receiver that is hooked up to it via a special wiring harness. It's pretty much the same thing as how some headunits can control and display an Ipod...
Posted on Mar 21, 2008
SOURCE:
Radio pro 4 wiring
You should purchase a radio harness for your car, and it's wires will connect to wires of the same color from your JVC radio harness. Join the two harnesses together (solder, crimp caps, barrel connectors, etc.) and then one end plugs into your JVC, the other end plugs into the factory harness that the original radio was connected to. If for some reason, your factory harness plug has been cut, you'll have to hardwire the JVC harness. I've included a link to the wiring diagram for your car. The steering wheel controls are moot; they will not work unless you've got some aftermarket adapter that allows them to interface with the JVC radio.
2004 pontiac grand prix speaker wiring diagram Google Search
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Nov 13, 2017 | Car Audio & Video
Have a 1996 Toyota Camery. Installed a KDG140 JVC stereo/CD player but the stereo won't work. CD player works great.
If "stereo won't work" refers to you not being able to get radio stations; try your antenna connection behind the radio. The vehicle may also have a power antenna connection(blue wire at the stereo).
Jul 28, 2011 | Car Audio & Video
I hooked up a JVC stero in my 1991 Nissan truck. Now the memory is wiped out for the radio + factory clock when I turn off the car. The radio will come back on, but no presets works.
Chances are that you do not have the constant 12 volt power of the vehicle connected to the memory wire of the stereo. The yellow memory wire of the stereo should be connected to the vehicles' battery. The red accessory wire of the stereo should connected to a switched 12 volt power source.
May 26, 2011 | JVC AM FM CD DET FACE CAR STEREO
How to memoriese radio channel. my jvc car radio whenever I set the station and when I switch off engine next time I have to tune again.pls solve my problem
Hello my name is Israel. The problem is with the wiring connection. You will need to make sure that the yellow wire is connected to a positive 12 volt source at all times. What is happening is that the wire is connected to a switched 12 volt. Reconnect wire to a constant 12 volt source. Good Luck.
Feb 14, 2011 | JVC AM FM CD DET FACE CAR STEREO
1986 NISSAN 300Z THE STEREO WIRE WERE CUT NEED COLOR CODE PLEASE TRYING TO INSTALLED A FTER MARKET STEREO JVC
i have attached the wiring info you requested. be sure to test all wires with a meter before connecting. also a link to metra's website if you need an installation kit
http://www.metraonline.com/fitl.aspx
Battery RED/BLACK (+) RADIO HARNESS Accesory BLUE (+) RADIO HARNESS Ground N/A THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS. Illumination RED/YELLOW (+) RADIO HARNESS Dimmer N/A Power Antenna GREEN/BLACK (+) RADIO HARNESS LF Speaker (+) BLUE/WHITE LF Speaker (-) BLUE/YELLOW RF Speaker (+) BROWN RF Speaker (-) BROWN/WHITE LR Speaker (+) RED LR Speaker (-) GREEN RR Speaker (+) BLUE RR Speaker (-) PINK
Sep 02, 2009 | JVC AM FM CD DET FACE CAR STEREO
Jvc kd-sx770 car stereo--radio works, but cd player doesn't
Hello beeswing70,
The player is recognizing that a CD has been inserted but is not able to read it.
Sometimes the lens assembly becomes contaminated and obscures the laser. I'd try using a commercial "lens cleaning CD" two or three times and then try a CD again. These lens cleaning CD's are widely available. If cleaning does not help, the player need professional service.
Hope this helps.
May 25, 2009 | JVC KD-SX770 CD Player
JVC KD-G200 won't power up any more.
Have you checked the fuse-box to make sure that you didn't blow the fuse for the radio? Also try removing the radio and checking the wiring to ensure that it is tight. There is also a fuse on the back of most radios to check!!
Nov 16, 2008 | JVC KD-G200 CD Player
JVC Car Stereo
The head unit should have two separate +12V connections: One that goes to a switched 12V power that is switched on/off via the ignition and one that is always energized at +12V. If the head unit's switched +12V lead is not connected, the unit will not turn on (except for when +12V is first applied to the "always on" lead, in which case it will immediately eject the CD). Please respond if this is not the issue. Hope this helps!
Mar 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-G720 CD Player Logo
79 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
