Question about Maytag MMV5186A Microwave Oven
Maytag Microwave model#MMV5186AA
My Maytag oven is not heating the food. I've checked all the operational buttons, the turntable are all working. No heat!!! The door sems to close with good closure. Will not heat food? It is four years old and only used by two people for supper? Any ideas?
  • 2 more comments
  • Anonymous Jun 27, 2008
    Exact same unit and same problem. 2 adults using the oven new in 2002 and now no heat.
    I will check the warrenty and cost of repair.
  • Anonymous Jul 23, 2008
    Our microwave does the same thing. We bought it in 2002. Everything works except it doesn't heat the food.
  • FixyaNoob Oct 01, 2008
    Same problem here but it does heat intermittently. I can try 10 times in a row and no heat (light, turntable, sounds are going but no heat), then suddenly it will start heating food.
    I've read that it could be the "safety interlock switch".
  • Anonymous Apr 03, 2009
    My MMV5186AA is no longer heating the food, AND, like the others, it was purchased in 2002. Everything else works. I was told it was the magnatron tube, most likely.
  • 2,130 Answers
Typically, no heating of food, indicates a bad Magnetron (tube) or associated components. The oven can be repaired. Magnetrons are not hard to replace and can be ordered online through MCM electronics www.mcmelectronics .
However, due to the dangers of high-voltage within the unit, I would recommend taking the unit to a repair center.
Look in the manual to see what the warranty says. See if there is any information regarding the magnetron or parts. You may be able to get it repaired for free parts, less labor.
Please let me know if I can be of further assistance to you.
Good Luck,
- Jim
Posted on Mar 20, 2008
Bosch microwave oven,turntable not working,food not heated
Even if the turntable isn't turning, the oven should still heat the food but it will be uneven cooking. I would suggest that the unit is not "microwaving" This is usually the high voltage capacitor, fuse or diode failure. You will need knowledge of how microwave ovens work and specialist tools to test these. If you don't, I would suggest you get a tech who does. There are extremely high voltages in microwave ovens.
Feb 23, 2015 | Bosch HMT75G451B Stainless Steel...
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
Does not heat food-master relay reset, all electric OK (fan runs, time & all other settings show OK, turntable rotates), door closed tightly, control lock
THere are three possibilities, open magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor.
Mar 14, 2012 | Maytag MMV1164WB Microwave Oven
The microwave isn't heating/cooking on any setting but the turntable, light is working. What should I check before calling a repairman?
There is nothing more you can do, you have verified everything is working except it is not heating the food. The next step is have the repairman come in to isolate the cause.
Jun 02, 2011 | Maytag MMV4205 Microwave Oven
Unit is 10 years old. Everything is working (keypad, lights, turntable) but unit is not heating food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Oct 06, 2010 | Maytag MMV5000 Microwave Oven
MMV5100AAB Over the Range 1500 watts 3amps -turntable does not turn -does not heat -light works- unit makes loud running noise but will not turn off -must open door or unplug to turn it off. Never any...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Sep 10, 2010 | Maytag Microwave Ovens
Maytag MMV5186A Microwave Oven Logo
636 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
