Question about Frigidaire ATF6000ES Front Load Washer
E70 message halfway through wash load ???
I keep getting this error and not sure what it means > Any help is greatly appreciated !
  • 868 Answers
It means you aren't getting cold water into your washer.It may be your hot & cold water hoses are backwards.Or check the screens in the valve and hoses make sure your cold is coming in .
Please rate this !!
Posted on Jun 10, 2008
    Problem Solver:
  • 7 Answers
Excellent repair Pro!!!!!
Posted on Jul 03, 2008
Frigidaire washer LTF7000ESO error code E70
Good Morning Jazy, this is JK. I see that you are receiving an error message E70. The E70 error means that the Main Control Board is not seeing the correct water supply. I would suggest swapping the hot and cold hoses. Hope this helps!
Mar 24, 2014 | Frigidaire Washing Machines
My washer will not complete a wash cycle and I keep getting the code E 70
The main cause for this e70 error is that the hoses would have swapped (hot to cold, cold to hot). It means the washer isn't getting cold water.Try to switch between the hoses. Another possibility is the faucets are not turned on.
Hope this solution will fix your problem for sure.
Thank You !!
Jun 21, 2010 | Frigidaire GLTF2940ES Front Load Washer
I am getting an error E70 have a frigidair Affinity Washer
Thank You !!
Jun 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
What does E70 means? My washing machine have this after it started for a few seconds.
hi,
Thank You !!
May 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
KEEP GETTING E70 MESSAGE
Are you sure its a E70? If so, the hot and cold lines are reversed.
Apr 25, 2010 | Frigidaire GLTF2940ES Front Load Washer
E70 error code
The main cause for this e70 error is that the hoses would have swapped (hot to cold, cold to hot). It means the washer isn't getting cold water.Try to switch between the hoses. Another possibility is the faucets are not turned on.... Hope this solution will fix your problem for sure.
Mar 30, 2010 | Frigidaire Affinity ATF7000E Front Load...
Stops within cycle E70 is error message
E70 Means that the Hot and Cold water lines are backwards. Switch the lines and cancel out the cycle. Turn the dial to drain and spin and pump all the water out of the unit. Then restart the cycle and it should be fine.
Feb 26, 2010 | Frigidaire ATF6000ES Front Load Washer
E70 ERROR SIGN
Great news that worked!! I had other issues with my washer and had a repair man come and fix it, when he left I started washing and that's when the E70 showed up uhh he hooked the hoses up wrong.. Thanks a bunch
Mar 11, 2008 | Frigidaire GLTF2940ES Front Load Washer
E70 error code repeatedly comes up when attempting to start a load and you have to cancel and restart 4-6 times before the load washes; again at the end of a load it will come up with the E70 error and to...
Means you are not getting cold water into unit..Either cold water hose is connected to the wrong hose or cold water faucet is not turned on..You can solve this by connecting hose to cold water faucet and cold water inlet on washer..
Nov 06, 2007 | Frigidaire GLTF2940ES Front Load Washer
E70
All w/machines have a maximum load capacity. Look for yours in the users'manual. Overloading could give you problems, bearings, etc. Your machine cld even have a half load switch.
Mar 26, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
65 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
