Question about RCA HD50LPW42 50" Rear Projection HDTV
Green color I have a RCA 50 in. DLP HDTV. Every channel has a green tint to everybody and everything. Green colors like grass and other things become lime colored instead of the correct green. I have it hooked up to DishNetwork but my other TV's are the right color. Could you help me fix this green problem?
  • 59 Answers
Hi...this could be the colorwheel. Very common in this model and an easy fix too.
Posted on Mar 28, 2008
I have a 61
Dial the tint adjustment
Dec 27, 2011 | RCA HD61LPW165 61" Projection HDTV
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
My RCA 55 inch DLP HDTV needs the color fixed. It keeps showing purple and green on the screen
color wheel is getting ready to fail which is causing the color wheel to spin slower which cause the index speed to be off so the tints will be messed up.
Aug 22, 2011 | RCA Televison & Video
The screen has a permenant green tinge which dominates all other colours. If watching football the grass insted of being bright grass colour green is more of a dull drab green
It could be the tint settings on your TV. Check your TV's settings menu for color/tint options. If you can't find it, break out the manual and look in the index for tint or color, then locate the page and it'll tell you how to get there.
Make sure the tint slider is in the middle, 0 or 50%, depending on your TV.
Best of luck.
Remember to rate my solutions! If you have time, drop a testimonial too - they really make my day. :)
Mar 29, 2010 | Sony BRAVIA KDL52XBR2 Television
Color went bad. Has a yellow/green tint to
This seems like a convergence issue and will need to be serviced.
There might be a chance of repairing the old convergence board but you will need to have the Tv looked at to determine what part on the convergence went bad.
Sep 20, 2009 | Toshiba 50HM67 50" HDTV
Green tint on Siny 50" DLP
Most likely a defective Light Engine Assembly. They normally cost about $800.00, or in that area.
Aug 14, 2009 | Sony KDS-R50XBR1 50" HDTV
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Color issue
Excuse me I meant COLOR adjustment.
Aug 18, 2008 | Sony KDS-50A2000 50" HDTV
RCA HD50LPW42 50" Rear Projection HDTV Logo
224 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
